Dock and access your SATA SSD/HDD through high-performance USB 3.1 (10Gbps) or eSATA. Connect and access any 2.5" or 3.5" SATA hard drive or SSD using this single-drive docking station, over a USB 3.1 Gen 2 (up to 10Gbps) or eSATA connection.
Ideal for IT professionals, the docking station lets you access a SATA solid-state drive or hard drive quickly, for drive imaging, data recovery, and backups.
You can connect through either USB 3.1 Gen 2 or eSATA, and take advantage of the high performance of the latest SSDs and HDDs.
The dock's vertical drive insertion makes it easy to dock and swap drives from your desktop computer or laptop. You simply insert your SSD or HDD into the drive slot at the top of the docking station, with no tools or trays required. The HDD ejection button allows fast and simple drive removal.
The single-bay docking station comes with a USB Type-A to Type-C cable, for connecting to newer USB-C enabled devices. It also comes with a USB Type-A to Type-B cable, providing backward compatibility with your existing USB 3.0, 2.0 and 1.x devices. An eSATA cable is also included with the dock.
The docking station is also UASP compatible, for enhanced performance.
Reliable hot-swap functionality
This docking station allows users to quickly and safely swap drives without the need to power down the device, promoting seamless transitions between data storage solutions. -
Broad compatibility
Compatible with both 2.5" and 3.5" SATA drives, the docking station caters to various storage needs, accommodating numerous applications. -
Enhanced data transfer speeds
Utilizing UASP transfer protocol and capable of supporting data transfer rates up to 6 Gbit/s, this docking station ensures that large files are handled swiftly and efficiently. -
Solid construction
Made from durable plastic, this HDD docking station is designed to withstand regular use, ensuring longevity for users relying on reliable storage solutions. -
Temperature resilient operation
Operating comfortably within a temperature range of 5°C to 35°C and a humidity range of 20 - 80%, this docking station is well-suited for a variety of environments.
- StarTech.com USB 3.1/eSATA Drive Docking Station for 2.5"/3.5" SATA Drives - External USB 3.1 (10Gbps) Hard Drive Dock w/ UASP (SDOCKU313E) - HDD docking station - SATA 6Gb/s - eSATA, USB 3.1 (Gen 2)
- HDD docking station - external
- Bays
- 1
- Bus Type
- Black
- Expansion Bays
- 1 x hot-swap - 2.5" / 3.5" shared
- Hard Drive Form Factor Compatibility
- 2.5", 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 6 Gbit/s
- Supported Devices
- Hard drive, solid state drive
- Max Storage Devices Qty
- 1
- Product Material
- Plastic
- Power
- AC 120/230 V
- 9.3 cm x 14.5 cm x 6.52 cm
- 500 g
- 2-year warranty
- Bays
- 1
- 2.5", 3.5"
- Host Bus
- Product Material
- Plastic
- Black
Storage Controller
- Interface
- SATA 6Gb/s
- 6 Gbit/s
- Supported Devices
- 1
- Processor
- ASMedia ASM1351
- Bays
- 1 x SATA 6Gb/s - SATA combo
- Connections
- 1 x USB 3.1 (Gen 2) - 9 pin USB Type B , 1 x eSATA - 7 pin external Serial ATA
- Cables Included
- 1 x USB cable - external - 1 m , 1 x USB-C cable - external - 1 m , 1 x eSATA cable - external - 1 m
- Tested with up to 6TB 7200 RPM hard drives, UASP transfer protocol
- FCC, RoHS
- Power adapter
- Voltage Required
- AC 120/230 V
- Limited warranty - 2 years
- 9.3 cm
- 14.5 cm
- 6.52 cm
- 500 g
- 5 °C
- 35 °C
- 20 - 80%
StarTech.com 6 ft Shielded External eSATA Cable M/M | In Stock | £9.58 |
StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap | In Stock | £3.33 |
StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks | In Stock | £19.65 |
StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) | In Stock | £14.51 |
StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M | In Stock | £7.61 |
StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter | In Stock | £15.57 |
StarTech.com mSATA SSD to 2.5in SATA Adapter Converter | In Stock | £18.13 |
StarTech.com USB 3.1 Enclosure for 2.5" SSD | In Stock | £26.43 |
StarTech.com USB 3.1 Gen 2 Single-bay Dock | In Stock | £53.68 |
StarTech.com USB 3.1 Gen 2 Dual-bay Dock | In Stock | £82.78 |
StarTech.com USB 3.1 / eSATA 1-bay Dock | In Stock | £54.05 |
