StarTech.com USB 3.0 / eSATA 6-Bay Hard Drive Duplicator Dock - 1:5 HDD / SSD Cloner and Eraser
Quicklinx: B0N4WS00 Mfr#: SATDOCK5U3ER
£721.31 ex VAT
£865.57 inc VAT
Exactly duplicate a 2.5in or 3.5in SATA hard drive to 5 hard drives simultaneously, or dock any of the 6 connected hard drives to your computer through USB 3.0 or eSATA. The SATDOCK5U3ER Hard Drive Duplicator & Docking Station lets you clone a 2.5in or 3.5in SATA hard drive (HDD) or solid-state drive (SSD) to five other SATA drives simultaneously, as a standalone device. The duplicator also lets you erase up to 5 drives, without a host connection.
You can also use the duplicator as a 5-bay HDD / SSD docking station, by connecting it to a host computer system through either USB 3.0 or eSATA. With support for high-capacity drives (tested with up to 6TB), this is a simple and cost-effective way to boost your data storage/backup capabilities.
By copying data from one drive to five drives simultaneously, the hard drive cloner helps boost your productivity by avoiding the hassle of repeatedly swapping drives in and out during high volume duplication projects.
Plus, the dock supports erasing up to five drives simultaneously with multiple operating modes, including Quick Erase as well as Multipass Overwriting (DoD) - the ideal solution for permanently erasing confidential information and helping to protect your business and your clients from identity theft.
With a built-in LCD display, the SATDOCK5U3ER makes it easy to monitor duplication progress and review copy/erase results and drive diagnostics during standalone operation.
The housing has also been specifically designed with ease-of-use in mind. The drive slots feature a dual-profile design to support hassle-free swapping between 2.5in and 3.5in hard drives and solid-state drives without having to use additional brackets or adapters.
With the option to connect the docking station through either eSATA or USB 3.0, the SATDOCK5U3ER provides a versatile solution for expanding the storage capability of almost any laptop or desktop computer. For fast performance, you can connect the docking station to your computer through eSATA for efficient data transfer speeds up to 3 Gbps. For broader system compatibility, you can connect the dock through USB 3.0, which is also backward compatible with USB 2.0/1.1 host connections.
The SATDOCK5U3ER also provides two charge-only, fast-charge USB ports, that you can use to keep your iPhone, iPad, and Android tablets or smartphones charged.
You can also duplicate, erase or access other drive types in duplication and quick-erase applications using a drive adapter. The following StarTech.com adapters have been tested to ensure compatibility with this drive duplicator: 2.5/3.5in IDE drives - SAT2IDEADP; mSATA drives - SAT2MSAT25; M.2 (NGFF) drives - SAT32M225.
Built for dependable, long-term performance the SATDOCK5U3ER is durably constructed.
StarTech.com 6 Bay USB 3.0/ eSATA Duplicator and Eraser Dock for 2.5" & 3.5" SATA SSD HDD - 1:5 Standalone Cloner & Wiper Docking Station (SATDOCK5U3ER) - hard drive duplicator
Hard drive duplicator
0 (installed) / 5 (max)
Supported Drives
SATA-300
North America, United Kingdom, Europe
Storage Controller
SATA (SATA 3Gb/s)
AC 120/230 V
15.18 cm x 31.5 cm x 7.5 cm
1.5 kg
Enclosure Colour
Chassis
0
Supported Devices / Modules Qty
5
Supported Drives
SATA-300
Storage Controller
SATA (SuperSpeed USB 3.0 / eSATA-300)
Interface Type
SATA 3Gb/s
Data Transfer Rate
300 MBps
Max Storage Devices Qty
5
Expansion Bays
5 (total) / 5 (free) x external - 2.5" / 3.5" shared
1 x USB 3.0 - 9 pin USB Type B , 1 x eSATA 3Gb/s - 7 pin external Serial ATA , 5 x SATA 3Gb/s - 22 pin Serial ATA
Built-in 2 cooling fans, rubber feet, LED indicator, tested with up to 6TB 7200 RPM hard drives
1 x USB cable , 1 x eSATA cable
FCC, RoHS
External power adapter
AC 120/230 V
15.18 cm
31.5 cm
7.5 cm
1.5 kg
5 °C
35 °C
20 - 80%
B0N4 StarTech.com 3 ft Shielded External eSATA Cable M/M In Stock £6.82
B0N4 StarTech.com 6 ft Shielded External eSATA Cable M/M In Stock £9.22
B0N4 StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap In Stock £3.90
B0N4 StarTech.com 3.5in Silicone Hard Drive Protector Sleeve with Connector Cap In Stock £5.44
B0N4 StarTech.com 4 Bay USB 3.0 eSATA to SATA Standalone 1:3 HDD Hard Drive Duplicator Dock In Stock £329.91
B0N4 StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) In Stock £8.03
B0N4 StarTech.com 2.5in SATA/SAS SSD/HDD to 3.5in SATA Hard Drive Converter In Stock £12.23
Price Range Ex VAT: 500 - 750
