StarTech.com SATA SSD/HDD Eraser/Dock - 4Kn
Quicklinx: CZD9WS00 Mfr#: SDOCK1EU3P2
Type: Hard Drive Eraser
HD Size: 2.5 / 3.5 shared
Power Supply: [N/A]
£232.95 ex VAT
£279.54 inc VAT
Make the most of your SATA drives. This standalone hard drive eraser makes it easy to re-use or re-purpose your 2.5" and 3.5" solid-state drives or hard drives, without connecting to a host computer. It works with most SATA SSDs and HDDs, including 4Kn drives, and offers printed confirmation when your drives have been securely erased.
The SSD/HDD eraser also gives you a single-bay dock for your SATA drive with fast USB 3.0 performance, also known as USB 3.1 Gen 1 (5Gbps).
Using industry-recognized erase modes, you can rest assured that the standalone eraser securely cleans, erases or sanitizes the data from your 2.5" or 3.5" SSD or HDD.
The hard drive eraser supports nine erase modes including Quick Erase, Single and Multi-pass Overwrites, Custom Erase, Secure Erase and Enhanced Secure Erase. The Multi-pass Overwrite (3-Pass Full Disk Overwrite) erase procedures meet the requirements of DoD (5220.22-M) standards.
The hard drive eraser lets you connect to an RS232 serial printer to print a record of the erase procedure and confirm that the erase has been successfully completed. This feature is ideal for IT technicians, system administrators or any departments needing confirmation when erasing sensitive or confidential information. For your reference, the printed receipt clearly shows you the time and date the drive was erased, as well as the erase mode used.
For IT technicians or business professionals who need to check files or test different hard drives, the dock makes it easy to hot-swap drives in and out as needed. It features a single SATA bay with a top-loading design for easy access to your drives, which makes it easy to quickly back-up or transfer data to a hard drive or solid-state drive.
With support for SATA I, II, and III and large-capacity drives, including 4Kn drives, this docking station is compatible with virtually any 2.5" or 3.5" SATA SSD or HDD.
The eraser dock also works with 2.5" and 3.5" IDE hard drives, mSATA drives and SATA M.2 drives using a compatible StarTech.com adapter: IDE hard drives: Use StarTech.com adapter SAT2IDEADP SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks; mSATA drives: Use StarTech.com adapter SAT32MSAT257 mSATA SSD to 2.5in SATA Adapter Converter; M.2 drives: Use StarTech.com adapter SAT32M225 M.2 NGFF SSD to 2.5in SATA Adapter Converter.
The hard drive eraser is OS independent, which ensures a quick and easy setup. Its compact design and small footprint enables you to easily tuck it into your workspace.
  • Industry-recognized erase modes
    Using industry-recognized erase modes, you can rest assured that the standalone eraser securely cleans, erases or sanitizes the data from your SSD or HDD.
  • Wipe sensitive data securely, confirmed with a printed receipt
    The hard drive eraser lets you connect to an RS-232 serial printer to print a record of the erase procedure and confirm that the erase has been successfully completed. This feature is ideal for IT technicians, system administrators or any departments needing confirmation when erasing sensitive or confidential information. For your reference, the printed receipt clearly shows you the time and date the drive was erased, as well as the erase mode used.
  • Easy drive management and wide compatibility
StarTech.com USB 3.0 Hard Drive Eraser Dock for 2.5" & 3.5" SATA SSD HDD + 4Kn Drive - LCD/ RS232 - Secure Erase HDD Wiper Docking Station (SDOCK1EU3P2) - hard drive eraser
Hard drive eraser
Package Content
USB 3.0 cable, external power adapter, drive eraser and dock
Bay Compatibility
2.5" / 3.5"
Storage Interface
SATA 6Gb/s
Product Material
Plastic, steel
12.3 cm x 14 cm x 7 cm
656 g
P/N: SVA12M5NA
Hard drive eraser
Bay Compatibility
2.5" / 3.5"
Storage Interface
SATA 6Gb/s
Product Material
Plastic, steel
Package Content
12.3 cm
14 cm
7 cm
656 g
LCD display, LED indicator, S.M.A.R.T. support, tested with up to 10TB 7200 RPM hard drives
P/N: SVA12M5NA
CZD9 StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap In Stock £3.30
CZD9 StarTech.com 4 Bay USB 3.0 eSATA to SATA Standalone 1:3 HDD Hard Drive Duplicator Dock In Stock £405.90
CZD9 StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) In Stock £12.07
CZD9 StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter In Stock £15.54
CZD9 StarTech.com mSATA SSD to 2.5in SATA Adapter Converter In Stock £17.99
CZD9 StarTech.com USB 3.0 / eSATA to 2.5 / 3.5" SATA HDD / SSD Duplicator Dock – Hard Drive Cloner 6Gbps In Stock £68.59
CZD9 StarTech.com USB 3.0 Standalone Eraser Dock In Stock £205.80
CZD9 StarTech.com SATA SSD/HDD Eraser/Dock - 4Kn In Stock £232.95
CZD9 StarTech.com StarTech.com Hard Drive Eraser In Stock £487.53
CZD9 StarTech.com M.2 SATA & M.2 NVMe Duplicator In Stock £732.76
Power Supply: [N/A]
