StarTech.com StarTech.com Hard Drive Eraser
Quicklinx: D0ZQWS00 Mfr#: SATERASER4
Type: Hard Drive Eraser
HD Size: 2.5 / 3.5 shared
Power Supply: [N/A]
£557.45 ex VAT
£668.94 inc VAT
Securely erase up to four SATA drives simultaneously with this standalone hard drive sanitizer. This hard drive eraser provides standalone, simultaneous drive erasing for up to four 2.5 in. or 3.5 in. SATA hard drives or solid-state drives.
Unlike hard-drive docking stations or adapters that require a computer connection and software to erase drives, this hard drive sanitizer features standalone erasing that doesn't require a host computer. This avoids the hassle of connecting your drives to a host computer and protects your drives from external security threats like remote data access.
The four-bay design maximizes efficiency by batching multiple drives in single erase projects, saving you valuable time. The hard drive eraser supports USB 3.0, also known as USB 3.1 Gen 1 (5 Gbps).
Using industry-recognized erase modes, the hard drive eraser securely sanitizes the data from your 2.5" or 3.5" SSDs or HDDs. It supports nine erase modes including Quick Erase, Single and Multi-pass Overwrites, Custom Erase, Secure Erase and Enhanced Secure Erase. The Multi-pass Overwrite (3-Pass Full Disk Overwrite) erase procedures meet the requirements of DoD (5220.22-M) standards.
Support for a variety of erase modes makes this drive eraser perfect for virtually any professional application. Single-Pass Overwrite is ideal for IT technicians and system administrators who decommission and repurpose old hard drives, while Quick and Secure Erase, Single Pass Overwrite and Multi-pass Overwrite modes (meeting DoD standards) are ideal solutions for research laboratories, health offices, law offices and accountants who manage sensitive data and require secure erasing to avoid potential privacy breaches.
In addition to supporting 2.5"/3.5" SATA SSDs and HDDs, the hard drive eraser also works with 2.5" and 3.5" IDE hard drives, mSATA drives and SATA M.2 drives using a compatible StarTech.com adapter. IDE hard drives: Use StarTech.com adapter SAT2IDEADP SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks. mSATA drives: Use StarTech.com adapter SAT32MSAT257 mSATA SSD to 2.5in SATA Adapter Converter. M.2 drives: Use StarTech.com adapter SAT32M225 M.2 NGFF SSD to 2.5in SATA Adapter Converter.
The hard drive eraser features convenient menu navigation that ensures fast and efficient performance, with push-button operation and a built-in LCD display that clearly identifies the erase modes and task status. You can also connect the eraser to a computer to quickly access the drive that's connected to port-1.
To ensure your records are complete for auditing, the hard drive eraser features a 9-pin serial port that can connect to a serial printer to provide on-demand erase logs.
StarTech.com 4 Bay SSD/HDD Hard Drive Eraser, 2.5" & 3.5" SATA, Hostless Standalone Secure Erase External Disk Sanitizer, 9 Erase Modes, RS232 Printer Port, NIST/DOD & TAA Compliant - Built-in LCD Display (SATERASER4) - hard drive eraser
Hard drive eraser
Package Content
USB 3.0 cable, external power adapter, 4 drive pads, 4 drive cables
Bay Compatibility
2.5" / 3.5"
Storage Interface
SATA 6Gb/s
AC 100-240 V
Product Material
Steel
11 cm x 20.9 cm x 3 cm
705 g
Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
Hard drive eraser
Bay Compatibility
2.5" / 3.5"
Storage Interface
SATA 6Gb/s
AC 100-240 V
Product Material
Steel
Package Content
11 cm
20.9 cm
3 cm
705 g
LCD display, LED indicator, tested with up to 10TB 7200 RPM hard drives
D0ZQ StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap In Stock £3.36
D0ZQ StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks In Stock £20.60
D0ZQ StarTech.com 4 Bay USB 3.0 eSATA to SATA Standalone 1:3 HDD Hard Drive Duplicator Dock In Stock £409.75
D0ZQ StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) In Stock £12.56
D0ZQ StarTech.com 2.5in SATA/SAS SSD/HDD to 3.5in SATA Hard Drive Converter In Stock £14.81
D0ZQ StarTech.com 2.5in SATA to Mini SATA SSD Adapter Enclosure In Stock £37.64
D0ZQ StarTech.com 1:2 Standalone USB 2.0 Flash Drive Duplicator and Eraser In Stock £118.08
D0ZQ StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter In Stock £18.77
D0ZQ StarTech.com mSATA SSD to 2.5in SATA Adapter Converter In Stock £19.82
D0ZQ StarTech.com USB 3.0 Standalone Eraser Dock In Stock £209.69
D0ZQ StarTech.com SATA SSD/HDD Eraser/Dock - 4Kn In Stock £234.88
D0ZQ StarTech.com M.2 SATA & M.2 NVMe Duplicator In Stock £691.38
Power Supply: [N/A]
Price Range Ex VAT: £500 - £750
