StarTech.com mSATA SSD to 2.5in SATA Adapter Converter
Quicklinx: 9CS8WS00 Mfr#: SAT32MSAT257
Hurry, only 1 left in stock!
£18.80 ex VAT
£22.56 inc VAT
Convert an mSATA SSD into a 7mm high 2.5in SATA 6Gbps Open Frame SSD. Vastly increase system performance by adding the speed of an mSATA SSD in any 2.5" SATA application, with the SAT32MSAT257 mSATA to SATA adapter.
Utilize the full potential of your SATA III controller, with an mSATA SSD reducing your DATA transfer bottle neck with file transfer speeds up to 6 Gbps. mSATA SSDs also save you money by reducing your power consumption over regular platter drives.
Help protect the health of your drive with an open frame design ensuring maximum heat dissipation.
  • Reliable connectivity
    The adapter features a 52 pin mini-SATA connector to ensure stable and efficient connection between mSATA drives and 2.5-inch SATA interfaces, enhancing compatibility with various storage devices.
  • Flexible installation
    Included mounting kit simplifies the process of installing the adapter, making it easy to incorporate into existing systems without the need for additional accessories.
  • Wide operating range
    With an operating temperature range from -40°C to 85°C, this adapter is suitable for use in diverse environments, ensuring reliable performance in both high-heat and cold conditions.
  • Standards compliant
    The adapter adheres to established FCC and RoHS standards, providing peace of mind regarding safety and environmental responsibility.
  • Efficient data handling
    Supporting a data transfer rate of 6 Gbit/s allows for swift data transfer and retrieval, improving the performance of connected solid state or hard drives.
StarTech.com mSATA SSD to 2.5in SATA Adapter Converter - mSATA to SATA Adapter for 2.5in bay with Open Frame Bracket and 7mm Drive Height (SAT32MSAT257) - storage controller - SATA 6Gb/s - SATA 6Gb/s
Storage controller - internal
Bus Type
SATA 6Gb/s
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive, solid state drive
Channel Qty
1
7 cm x 10 cm x 0.7 cm
100 g
P/N: BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET425F, SATDOCK5U3ER, SATERASER4, SDOCK1EU3P, SDOCK1EU3P2, SDOCK4U313, SDOCKU313, SDOCKU313E, USB312SAT3, USB31C2SAT3, USB31CSAT3CB
Host Bus
SATA 6Gb/s
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Channel Qty
1
1 x SATA 6Gb/s - SATA power
1 - 52 pin mini-SATA
Mounting Kit
Included
FCC, RoHS
7 cm
10 cm
0.7 cm
100 g
-40 °C
85 °C
9CS8 StarTech.com 24" Serial ATA Cable In Stock £5.28
9CS8 StarTech.com 18" Serial ATA Cable w/R Angle In Stock £5.00
9CS8 StarTech.com 18in SATA Serial ATA Data and Power Combo Cable In Stock £6.02
9CS8 StarTech.com 18in SATA Serial ATA Cable In Stock £4.44
9CS8 StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter In Stock £4.26
9CS8 StarTech.com 24in SATA to Right Angle SATA Serial ATA Cable In Stock £5.36
9CS8 StarTech.com 12in Latching SATA Cable In Stock £5.50
9CS8 StarTech.com 12in SATA Serial ATA Cable In Stock £4.46
9CS8 StarTech.com 6in SATA to LP4 Power Cable Adapter - F/M In Stock £5.79
9CS8 StarTech.com 18in SATA to Left Angle SATA Serial ATA Cable - F/F In Stock £6.14
9CS8 StarTech.com 8in Latching SATA to SATA Cable - F/F In Stock £5.30
9CS8 StarTech.com 6in SATA to Left Angle SATA Serial ATA Cable In Stock £3.92
9CS8 StarTech.com 2.5in SATA to Mini SATA SSD Adapter Enclosure In Stock £30.84
9CS8 StarTech.com Dual 2.5" to 3.5" HDD Bracket for SATA Hard Drives - 2 Drive 2.5" to 3.5" Bracket In Stock £7.33
9CS8 StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter In Stock £16.20
9CS8 StarTech.com mSATA SSD to 2.5in SATA Adapter Converter In Stock £18.80
9CS8 StarTech.com Dual mSATA SSD to 2.5" SATA RAID Adapter Converter In Stock £35.55
9CS8 StarTech.com M.2 NGFF to SATA Adapter In Stock £21.11
9CS8 StarTech.com Dual M.2 NGFF SATA Adapter w/ RAID - 2x M.2 SSDs to 2.5in SATA In Stock £31.73
9CS8 StarTech.com x4 PCI Express to M.2 PCIe SSD Adapter In Stock £19.59
9CS8 StarTech.com M.2 to U.2 Adapter In Stock £24.14
9CS8 StarTech.com x8 Dual M.2 PCI Express SSD Adapter - PCIe 3.0 for PCIe NVMe In Stock £135.99
9CS8 StarTech.com 18in Right Angle SATA Cable In Stock £4.36
