StarTech.com 6in SATA to Left Angle SATA Serial ATA Cable
Quicklinx: 7RXCWS00 Mfr#: SATA6LA1
Length: 15.2cm
Type: SATA
19 In Stock
£3.93 ex VAT
£4.71 inc VAT
Make a Left-Angled Connection to your SATA Drive, for Installation in Tight Spaces. The SATA6LA1 Left Angle (90-degree) SATA Cable features a standard (straight) SATA receptacle as well as a left-angled SATA receptacle, providing a simple 6-inch connection to a Serial ATA drive, with full SATA 3.0 bandwidth support of up to 6Gbps when used with SATA 3.0 compliant drives.
The left-angled SATA connection enables you to plug in your Serial ATA hard drive in hard to reach areas or tight spaces, while the low profile and flexible design of the cable improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
As an alternative, StarTech.com also offers a 6in Right Angle SATA cable (SATA6RA1), which provides the same simple installation as this left angled SATA cable, but allows the cable to connect to the SATA drive from the opposite direction.
StarTech.com 6in SATA to Left Angle SATA Serial ATA Cable - 6in SATA Cable - left angle SATA Cable - angled SATA Cable - SATA cable - 15.2 cm
SATA cable
Interface Speed
Serial ATA 150/300/600
Shielded
Left-angled connector
Length
15.2 cm
Connector
7 pin Serial ATA - receptacle
Connector (Second End)
Red
P/N: 25S22M2NGFFR, 25SAT22MSAT, S322M225R, SAT2M2NGFF25, SAT32M225, SAT32MSAT257, USB2SATAIDE, USB3SSATAIDE
Storage Cable Type
SATA cable
Interface Speed
Shielded
Shielding Material
American Wire Gauge (AWG)
26
Length
15.2 cm
Red
Connector
RoHS
7RXC StarTech.com 18" Serial ATA Cable w/R Angle In Stock £5.00
7RXC StarTech.com 6in SATA Serial ATA Cable In Stock £3.61
7RXC StarTech.com 6in Latching SATA Cable In Stock £2.60
7RXC StarTech.com 6in SATA to Left Angle SATA Serial ATA Cable In Stock £3.93
7RXC StarTech.com 6in SATA to Right Angle SATA Serial ATA Cable In Stock £3.90
Length: 15.2cm
Type: SATA
