StarTech.com 8in Latching SATA to SATA Cable - F/F
Quicklinx: 7NZHWS00 Mfr#: LSATA8
Length: 20cm
Type: SATA
More than 50 In Stock
£5.44 ex VAT
£6.52 inc VAT
Secure latching SATA cable designed for new system boards and SATA hard drives. The LSATA8 SATA Cable features two latching 7-pin data receptacles and supports full SATA 3.0 bandwidth of up to 6Gbps when used with SATA 3.0 compliant drives.
The latching connectors lock when connected to a supporting (latchable) SATA port, ensuring a snug, and secured data connection every time to prevent accidental disconnects.
Featuring a low profile, yet durable construction, the flexible design improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
StarTech.com 8in Latching SATA to SATA Cable - F/F - SATA cable - 20 cm
SATA cable
Interface Speed
Serial ATA 150/300/600
Latched
Length
20 cm
Connector
7 pin Serial ATA - receptacle
Connector (Second End)
Red
P/N: 10P6G-PCIE-SATA-CARD, 25S22M2NGFFR, 25SAT22MSAT, 2P6G-PCIE-SATA-CARD, 35S24M2NGFF, 4P6G-PCIE-SATA-CARD, 6P6G-PCIE-SATA-CARD, HSB13SATSASB, HSB1SATSASBA, HSB1SATSASVA, HSB43SATSASB, HSB4SATSASBA, PEXMSATA3422, PEXMSATA343, S322M225R, SAT2M2NGFF25, SAT32M225, SAT32MSAT257, SATSASBP425
Storage Cable Type
SATA cable
Interface Speed
American Wire Gauge (AWG)
26
Latched
Length
20 cm
Red
Connector
RoHS
P/N: 10P6G-PCIE-SATA-CARD, 25S22M2NGFFR, 25SAT22MSAT, 2P6G-PCIE-SATA-CARD, 35S24M2NGFF, 4P6G-PCIE-SATA-CARD, 6P6G-PCIE-SATA-CARD, BRACKET25X2, HSB13SATSASB, HSB1SATSASBA, HSB1SATSASVA, HSB3SATSASBA, HSB43SATSASB, HSB4SATSASBA, PEXMSATA3422, PEXMSATA343, PEXSAT34RH, S322M225R, SAT2M2NGFF25, SAT32M225, SAT32MSAT257, SATSASBP425, USB2SATAIDE, USB3SSATAIDE
7NZH StarTech.com 18" Serial ATA Cable w/R Angle In Stock £5.00
7NZH StarTech.com 12in Latching SATA Cable In Stock £6.16
7NZH StarTech.com 18in Latching SATA Cable In Stock £4.24
7NZH StarTech.com 24in Latching SATA Cable In Stock £6.84
7NZH StarTech.com 12in Latching SATA to Right Angle SATA Serial ATA Cable In Stock £4.98
7NZH StarTech.com 8in Latching SATA to SATA Cable - F/F In Stock £5.44
Length: 20cm
Type: SATA
