StarTech.com U.2 2.5" NVMe SSD Adapter
Quicklinx: C9X0WS00 Mfr#: PEX4SFF8643
Add high-performance enterprise-class storage to your PC or server, by connecting a 2.5" PCIe U.2 SSD. Unleash the performance of your desktop PC or server with this enterprise-class drive adapter. By providing compatibility with newer U.2 NVMe SSDs, such as the Intel SSD 750 series, you can gain faster read/write speeds and higher productivity levels for data-intensive applications.
This drive adapter provides an ideal way to upgrade legacy motherboard platforms and your existing computer system, by adding compatibility for newer U.2 NVMe SSDs, which are designed to meet the high-performance needs of today's data centers and enterprise-level applications.
The adapter card enables IT professionals and system integrators to upgrade their computing infrastructure by installing the adapter card into the PCIe slots on desktop PCs or servers. Upgrading, rather than replacing computing infrastructure, provides a cost-effective way to enhance your system's performance.
U.2 NVMe SSDs also offer superior energy efficiency, providing an advantage to companies looking to reduce energy costs.
Companies and organizations with intensive file workloads can achieve greater productivity by upgrading their data center or enterprise-level applications with U.2 NVMe SSD capability. U.2 SSDs are up to four times faster than SATA SSDs, providing extremely fast read/write speeds, high-speed file access and transfers, and rapid boot times. U.2 NVMe SSDs are also more reliable than SATA hard drives, so less time is spent waiting for computers to boot, or applications and files to load.
Through U.2 NVMe SSD capability, the drive adapter brings enhanced productivity for numerous data-heavy applications. Office professionals, from architects and engineers to healthcare professionals, can quickly access and edit large documents, spreadsheets, or 3D models and renderings. Creative professionals, including content creators and graphic designers, can work more productively on photo editing, video production and editing of large image or audio files.
The drive adapter also saves time for gaming enthusiasts, with much faster launch times and level changes.
The U.2 SSD adapter lets you add a PCIe NVMe 2.5 in. SSD to a computer system that doesn't natively support U.2 PCIe NVMe. The adapter simply connects to your computer's 4-lane or greater PCI Express slot and enables you to connect a U.2 SSD to your PC through the provided SFF-8643 interface, using an SFF-8643 to U.2 cable. The PCIe 2.5 in. NVMe SSD adapter is compatible with PCIe 3.0 and PCIe 2.0 motherboards.
The drive adapter comes with a full-profile bracket (preinstalled), and also includes a low-profile bracket that makes it easy to install the card in a small form-factor computer.
Startech 4-Lane PCI Express to SFF-8643 Adapter for PCIe NVMe U.2 SSD - U.2 2.5" NVMe SSD Adapter (PEX4SFF8643) - interface adapter - SAS 12Gb/s - PCIe x4
Interface adapter - plug-in card
Bus Type
PCIe x4
Red
Supported Form Factor
Expansion Slot to U.2
Expansion Bays
1 x internal - 2.5"
Hard Drive Form Factor Compatibility
2.5"
SAS 12Gb/s
Supported Devices
Solid state drive
2.2 cm x 9.3 cm x 8 cm
27.2 g
2.5"
Host Bus
PCIe x4
Red
Storage Controller
SAS 12Gb/s
Supported Devices
Solid state drive
Bays
1 x internal - 2.5"
Low-profile bracket, full-profile bracket
FCC, RoHS, WEEE, RCM
2.2 cm
9.3 cm
8 cm
27.2 g
5 °C
50 °C
15 - 90%
C9X0 StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter In Stock £15.57
C9X0 StarTech.com M.2 SATA external SSD enclosure USB 3.0 with UASP In Stock £19.88
C9X0 StarTech.com Tool-Less 2B Mounting Bracket In Stock £6.49
C9X0 StarTech.com 2x M.2 SSD Controller - PCIe In Stock £21.26
C9X0 StarTech.com x4 PCI Express to M.2 PCIe SSD Adapter In Stock £18.76
C9X0 StarTech.com 2x SFF-8643 to 8644 Adapter In Stock £68.29
C9X0 StarTech.com 2.5" SSD/HDD Mounting Bracket In Stock £4.64
C9X0 StarTech.com U.2 to PCIe Adapter -SFF-8639 In Stock £27.51
C9X0 StarTech.com M.2 to U.2 Adapter In Stock £23.11
C9X0 StarTech.com M.2 NVMe SSD Enclosure for PCIe SSDs - USB 3.1 Gen 2 Type-C In Stock £40.35
C9X0 StarTech.com USB PCIE/SATA M.2 Enclosure In Stock £45.80
