Turn your PCIe M.2 NVMe or SATA AHCI M.2 SSD into a highly portable, USB-based external storage solution. This enclosure features USB 3.1 Gen 2 (10Gbps) with UASP support & PCIe 3.0 delivering real read/write data transfer speeds up to 1GB per second. Working with both PCIe and SATA based drives, this enclosure ensures compatibility with many M.2 drives, supporting both M-Key (PCIe) and B+M-Key (SATA) drives sized 2230/2242/2260/2280. The enclosure is also forward compatible with PCIe 4.0 based drives, at reduced PCIe 3.0 performance. USB 3.1 Gen 2 10Gbps (also known as USB 3.2 Gen 2x1) is backward compatible with USB 3.1 Gen 1 5Gbps (also known as USB 3.0), USB 2.0, and USB 1.1.
All-in-One M.2 and USB Solution
With compatibility for both PCIe NVMe and SATA based M.2 drives, this enclosure solves the common challenge of identifying which enclosure is compatible with your M.2 drive. Regardless of whether your M.2 drive is SATA or PCIe NVMe based, you can rest assured that this enclosure will provide a high-performance solution for turning your M.2 drive into a portable external enclosure. For further compatibility the enclosure works with multiple drive lengths supporting 2230, 2242, 2260 and 2280mm drives including Samsung (850, 860, 870, 950, 960, 970) Kingston, Seagate, Western Digital (WD), HP, and Intel SSD drives. For multiplatform support this enclosure, the enclosure features a USB-C host connection, and includes two different 12 in. (30 cm) host cables, a USB-C to USB-C cable and a USB-C to USB-A cable. This combined with the backward compatibility of the USB protocol, ensures that this M.2 enclosure will work with virtually any computer, whether it's USB-A, USB-C or Thunderbolt 3/4. -
Tool-Free Drive Installation
The external M2 SATA or M.2 NVMe SSD enclosure case supports driverless plug-and-play installation and features tool-less drive installation, so you can install your drive with no tools required. -
Unparalleled Performance
Leverage the high speeds of your M.2 NVMe or SATA drive, with this external SSD enclosure. It delivers USB 3.2 Gen 2x1 maximum theoretical throughput of 10Gbps, which is twice the throughput of USB 3.2 Gen 1x1 at 5Gbps. The enclosure also supports PCIe 3.0 which when combined with an M.2 NVMe drive takes full advantage of the throughput available to USB 3.2 Gen 2x1. This fan-less aluminum enclosure features ventilation holes for maximum heat dissipation, ensuring your drive operates noiselessly at an optimal temperature to preserve performance and protect your drive from overheating damage. -
Durable and Portable
This slim, pocket-sized enclosure for PCIe NVMe or SATA based M.2 drives is specially designed for mobility, with a small form-factor design that fits easily into your laptop bag. Its lightweight, yet durable aluminum housing helps to ensure your drive won't be damaged while you're on the move. M2-USB-C-NVME-SATA is backed by a StarTech.com 2-year warranty and free lifetime technical support.
- StarTech.com USB-C 10Gbps to M.2 NVMe or M.2 SATA SSD Enclosure, Tool-free M.2 PCIe/SATA NGFF SSD Enclosure, Portable Aluminum Case, USB Type-C & USB-A Host Cables, For 2230/2242/2260/2280 - Works w/ Thunderbolt 3 (M2-USB-C-NVME-SATA) - storage enclosure - M.2 Card (PCIe NVMe & SATA) - USB-C 3.2 (Gen 2)
- Storage enclosure - external
- Bus Type
- USB-C 3.2 (Gen 2)
- Space grey
- Expansion Bays
- 1 x internal - M.2 NGFF 2230/2242/2260/2280
- Hard Drive Form Factor Compatibility
- M.2
- Interface
- Data Transfer Rate
- 10 Gbit/s
- Supported Devices
- Solid state drive
- Max Storage Devices Qty
- 1
- Product Material
- Aluminium
- Power Source
- USB bus
- 10.5 cm x 3.5 cm x 1.4 cm
- 52 g
- M.2
- Host Bus
- USB-C 3.2 (Gen 2)
- Product Material
- Aluminium
- Space grey
Storage Controller
- Interface
- 10 Gbit/s
- Supported Devices
- Solid state drive
- 1
- Bays
- 1 x SATA 6Gb/s / PCIe 4.0 (NVMe) - M.2 M+B/M Key (internal)
- Connections
- 1 x USB 3.2 (Gen 2) - 24 pin USB-C
- Included Accessories
- Thermal pad, SSD fastener pegs
- Cables Included
- 1 x USB-C to USB-C cable - external - 30 cm , 1 x USB-C to USB-A cable - external - 30 cm
- Supports AHCI mode, LED indicator, 4Kn drive compatible, TRIM support
- MTBF
- 112,000 hours
- UASP (USB Attached SCSI Protocol)
- Power Source
- USB bus
- 10.5 cm
- 3.5 cm
- 1.4 cm
- 52 g
- Shipping Width
- 17 cm
- Shipping Depth
- 14.2 cm
- Shipping Height
- 2.8 cm
- Shipping Weight
- 75 g
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
StarTech.com 1m USB 3.1 USB-C to USB-A Cbl | In Stock | £7.59 |
StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M | In Stock | £13.21 |
StarTech.com 0.5m USB C Cable - USB 3.1 | In Stock | £13.10 |
StarTech.com 0.5m USB to USB-C Cable 10Gbps | In Stock | £8.26 |
