Easily install one 2.5" solid-state drive or hard drive into a 3.5" bay, without requiring any additional hardware or tools. This mounting bracket lets you quickly install a 2.5" SSD or HDD into a single 3.5" bay in a desktop PC or server, with no tools required. The tool-less mounting bracket supports a 2.5" solid-state drive or hard drive from 7 mm to 9.5 mm in height.
The mounting bracket's tool-less design makes it fast and easy to install a 2.5" drive in a computer or server, without the need for additional hardware or tools. It's ideal for system administrators and integrators who are building or upgrading a computing solution for a wide range of businesses and organizations, including schools and hospitals, saving valuable time and effort on installation projects.
The lightweight mounting bracket is designed for trouble-free, reliable performance. To install a drive, you simply secure it into the mounting bracket, without using tools. Then, you put the bracket into a 3.5" drive bay in your computer and the bracket holds the drive in place using the tool-less plastic pegs.
Effortless installation
The 2.5" HDD / SDD Mounting Bracket for 3.5" Drive Bay features a toolless design, allowing for quick and easy installation without the need for additional tools. This hassle-free setup makes it an ideal solution for upgrading your PC storage with speed and ease. -
Versatile compatibility
Designed to fit both 2.5" HDDs and SSDs into a 3.5" drive bay, this adapter bracket ensures a seamless fit for a wide range of desktop setups. Its compatibility with 8.9 cm to 6.4 cm form factors accommodates various storage devices, enhancing the flexibility of your system's storage options. -
Durable construction
Crafted from high-quality plastic, the BRACKET125PT stands up to the rigors of regular use. This durability, combined with compliance to RoHS and WEEE standards, ensures a reliable solution for your storage needs while also adhering to environmental regulations.
- StarTech.com 2.5" HDD / SDD Mounting Bracket for 3.5" Drive Bay - Tool-less Installation - 2.5 Inch SSD HDD Adapter Bracket (BRACKET125PT) - storage bay adapter
- Storage bay adapter
- Black
- Supported Form Factor
- 3.5" to 2.5"
- Expansion Bays
- 1 x internal - 2.5"
- Compatible Bay
- 1 3.5"
- Product Material
- Plastic
- 10.2 cm x 15 cm x 1.3 cm
- 35 g
- 2-year warranty
- Designed For
- P/N: M2E4SFF8643, PEX4SFF8643, U2M2E125
- 3.5" to 2.5"
- Product Material
- Plastic
- Black
Storage Controller
- Processor
- No CPU
- Bays
- Compatible Bay
- 1 x internal 3.5"
- Included Accessories
- 6 plastic pegs
- RoHS, WEEE
- Limited warranty - 2 years
- 10.2 cm
- 15 cm
- 1.3 cm
- 35 g
- Designed For
StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter | In Stock | £4.58 |
StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter | In Stock | £4.24 |
StarTech.com 12in Latching SATA Cable | In Stock | £5.48 |
StarTech.com 18in Latching SATA Cable | In Stock | £4.40 |
StarTech.com 24in Latching SATA Cable | In Stock | £6.08 |
StarTech.com 3.5in Hard Drive to 5.25in Front Bay Bracket Adapter | In Stock | £5.44 |
StarTech.com 6in SATA Power Y Splitter Cable Adapter - M/F | In Stock | £6.62 |
StarTech.com 6in Latching SATA Cable | In Stock | £5.08 |
StarTech.com 4x SATA Power Splitter Adapter Cable | In Stock | £6.36 |
StarTech.com Dual 2.5" to 3.5" HDD Bracket for SATA Hard Drives - 2 Drive 2.5" to 3.5" Bracket | In Stock | £7.33 |
StarTech.com 2.5" to 3.5" SATA Aluminium Hard Drive Adapter Enclosure SSD / HDD Height up to 12.5mm | In Stock | £19.99 |
StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter | In Stock | £16.17 |
StarTech.com mSATA SSD to 2.5in SATA Adapter Converter | In Stock | £18.80 |
StarTech.com Tool-Less 2B Mounting Bracket | In Stock | £6.61 |
StarTech.com 6" SATA Power Y Splitter Cable | In Stock | £6.62 |
StarTech.com 2.5 to 3.5 Hard Drive Adapter | In Stock | £23.64 |
