StarTech.com Rackmount KVM Console - 16 Ports with 17" LCD Monitor
Quicklinx: F2GKWS00 Mfr#: RKCONS1716K
Type: KVM switch
Ports: 16
Connectivity: KVM
Hurry, only 3 left in stock!
£1,235.87 ex VAT
£1,483.04 inc VAT
Providing centralized control of up to 16 servers, this 16-port rackmount KVM console gives you easy access to your systems. With a minimal footprint, it mounts in a server rack or cabinet using only 1U of rack space.
The 1U rackmount console features a built-in keyboard, and a touchpad for intuitive control, as well as a 17-inch LCD display that supports resolutions up to 1280x1024.
This 16-port KVM console comes with everything you need to set up right out of the box: 16 VGA KVM Cables; Mounting Rails; M5 Cage Nuts and Screws.
With direct access to 16 systems or servers, the 16-port KVM module gives you the flexibility you need to easily integrate the console into your existing server infrastructure.
Rack consoles provide convenient, rack-mounted control options for single servers or the entire server room. KVM consoles include LCD display, keyboard, and trackpad, all sliding into 1U of rack space.
StarTech.com 16 Port Rackmount KVM Console w/ Cables - Integrated KVM Switch w/ 17" LCD - 1U LCD KVM Drawer 50000 MTBF - USB + VGA Support (RKCONS1716K) - KVM console - 17"
KVM console - 17"
KVM Switch
PS/2, USB - 16 ports
Keyboard, touchpad, 16 port KVM switch
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 60 Hz
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
16.7 million colours
Input Connectors
VGA
Voltage
AC 120/230 V
44.8 cm x 58.1 cm x 4.25 cm
Height (Rack Units)
1U
13.7 kg
Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
Display Type
KVM console / TFT active matrix
Diagonal Size
17"
Built-in Devices
16 port KVM switch
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Height (Rack Units)
1U
13.7 kg
Input
Keyboard, touchpad
KVM
KVM switch - 16 ports
Keyboard / Mouse Interface
PS/2, USB
Max Resolution
1280 x 1024 @ 60 Hz
16 x VGA , 2 x USB 2.0 (Type A) , 2 x PS/2 , VGA output , Daisy chain port (HD-15)
8 x M5 cage nuts, 8 x M5 screws, 2 x mounting rails
16 x keyboard / mouse / video cable - 1.83 m
Rack Mounting Kit
Included
MTBF
50,000 hour(s)
Input Voltage
AC 120/230 V
Power Consumption (Typical)
23 Watt
Shipping Weight
21 kg
10 - 80% (non-condensing)
F2GK StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £7.01
F2GK StarTech.com 19in Cable Management Panel In Stock £24.78
F2GK StarTech.com 8 Port KVM Console for Server Rack - 19in In Stock £1,210.08
F2GK StarTech.com Single Server KVM Console for Server Rack -19" In Stock £753.19
F2GK StarTech.com 16 port KVM VGA Console with KVM Switch - 19" In Stock £1,308.21
F2GK StarTech.com 17" Dual Rail Rackmount KVM Console with 1080p In Stock £1,163.23
F2GK StarTech.com Rackmount KVM Console - 16 Ports with 17" LCD Monitor In Stock £1,235.87
F2GK StarTech.com 1U HD Single Server KVM In Stock £802.08
F2GK StarTech.com 10 ft. (3 m) USB KVM Cable for Rackmount Consoles In Stock £31.81
F2GK StarTech.com 15 ft. (4.6 m) USB KVM Cable for Rackmount Consoles In Stock £43.88
F2GK StarTech.com 6 ft. (1.8 m) USB KVM Cable for Rackmount Consoles In Stock £19.43
Type: KVM switch
Ports: 16
Connectivity: KVM
Price Range Ex VAT: £1000 - £1500
