Providing centralized control of up to 16 servers, this 16-port rackmount KVM console gives you easy access to your systems. With a minimal footprint, it mounts in a server rack or cabinet using only 1U of rack space.
The 1U rackmount console features a built-in keyboard, and a touchpad for intuitive control, as well as a 17-inch LCD display that supports resolutions up to 1280x1024.
This 16-port KVM console comes with everything you need to set up right out of the box: 16 VGA KVM Cables; Mounting Rails; M5 Cage Nuts and Screws.
With direct access to 16 systems or servers, the 16-port KVM module gives you the flexibility you need to easily integrate the console into your existing server infrastructure.
Rack consoles provide convenient, rack-mounted control options for single servers or the entire server room. KVM consoles include LCD display, keyboard, and trackpad, all sliding into 1U of rack space.
Efficient space-saving design
The rack-mountable form factor allows for easy installation in standard 1U racks, helping to optimize workspace and keep environments organized. -
High-quality display performance
Featuring a diagonal size of 17 inches and a contrast ratio of 1000:1, the display provides clear, sharp images and supports 16.7 million colors for vibrant visuals. -
Robust connectivity options
The KVM console supports a range of connections including USB 2.0 and PS/2, ensuring compatibility with various devices and systems for versatile use. -
Reliable operational longevity
Boasting a mean time between failures (MTBF) of 50,000 hours, this console is built for durability and consistent performance in demanding environments.
- StarTech.com 16 Port Rackmount KVM Console w/ Cables - Integrated KVM Switch w/ 17" LCD - 1U LCD KVM Drawer 50000 MTBF - USB + VGA Support (RKCONS1716K) - KVM console - 17"
- KVM console - 17"
- KVM Switch
- PS/2, USB - 16 ports
- Keyboard, touchpad, 16 port KVM switch
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024 at 60 Hz
- Pixel Pitch
- 0.264 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- 16.7 million colours
- Input Connectors
- VGA
- Voltage
- AC 120/230 V
- Black
- 44.8 cm x 58.1 cm x 4.25 cm
- Height (Rack Units)
- 1U
- 13.7 kg
- Localisation
- Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
- 2-year warranty
- Display Type
- KVM console / TFT active matrix
- Diagonal Size
- 17"
- Built-in Devices
- 16 port KVM switch
- Aspect Ratio
- 5:4
- Native Resolution
- Pixel Pitch
- 0.264 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Black
- 1U
- 13.7 kg
Input
KVM
- KVM switch - 16 ports
- Keyboard / Mouse Interface
- PS/2, USB
- Max Resolution
- 1280 x 1024 @ 60 Hz
- 16 x VGA , 2 x USB 2.0 (Type A) , 2 x PS/2 , VGA output , Daisy chain port (HD-15)
- Included Accessories
- 8 x M5 cage nuts, 8 x M5 screws, 2 x mounting rails
- Cables Included
- 16 x keyboard / mouse / video cable - 1.83 m
- Rack Mounting Kit
- Included
- MTBF
- 50,000 hour(s)
- Localisation
- Input Voltage
- AC 120/230 V
- Power Consumption (Typical)
- 23 Watt
- Shipping Weight
- 21 kg
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) | In Stock | £3.06 |
StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) | In Stock | £6.36 |
StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel | In Stock | £38.59 |
StarTech.com 19in Cable Management Panel | In Stock | £24.18 |
StarTech.com 8 Port KVM Console for Server Rack - 19in | In Stock | £1,162.96 |
StarTech.com Single Server KVM Console for Server Rack -19" | In Stock | £749.12 |
StarTech.com 16 port KVM VGA Console with KVM Switch - 19" | In Stock | £1,320.56 |
StarTech.com 17" Dual Rail Rackmount KVM Console with 1080p | In Stock | £927.37 |
StarTech.com Rackmount KVM Console - 16 Ports with 17" LCD Monitor | In Stock | £1,151.88 |
StarTech.com 1U HD Single Server KVM | In Stock | £803.46 |
StarTech.com 10 ft. (3 m) USB KVM Cable for Rackmount Consoles | In Stock | £30.11 |
StarTech.com 15 ft. (4.6 m) USB KVM Cable for Rackmount Consoles | In Stock | £40.34 |
StarTech.com 6 ft. (1.8 m) USB KVM Cable for Rackmount Consoles | In Stock | £17.59 |
