StarTech.com PCI Express Wireless N Adapter - 300 Mbps PCIe 802.11 b/g/n Network Card – 2T2R 2.2 dBi
Quicklinx: 8G47WS00 Mfr#: PEX300WN2X2
  • Windows 8 (32/64 bits)
  • IEEE 802.11n
Add high speed Wireless-N connectivity to a desktop PC through PCI Express. The PEX300WN2X2 PCI Express Wireless N Card (PCIe x1) adds high speed wireless network connectivity to almost any PCI Express-enabled desktop/workstation PC. Using a 2T2R (2 Transmitter/2 Receiver) design over the 2.4GHz frequency, this PCIe wireless card provides up to 300Mbps of data bandwidth over an 802.11n network, while improving signal reception and range.
Backward compatible with 802.11b/g networks (11/54Mbps), this WiFi N adapter offers a versatile wireless networking solution with support for standard and advanced security options such as WEP, WPA and WPA2, along with wireless Quality of Service (QoS) support and quick and easy setup through WPS.
StarTech.com PCI Express Wireless N Card - 300 Mbps PCIe 802.11 b/g/n Network Adapter Card - 2T2R 2.2 dBi - PCIe Wireless Desktop Card (PEX300WN2X2) - network adapter - PCIe
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express x1
1.8 cm x 12 cm x 7.5 cm
15 g
802.11b/g/n
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Linux Kernel 2.6.32, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
Network adapter
PCI Express x1
Wireless
Spread Spectrum Method
OFDM, DSSS
Data Transfer Rate
300 Mbps
Line Coding Format
DBPSK, DQPSK, CCK
Frequency Band
2.4 GHz
Status Indicators
Link/activity
WMM support, QoS, WPS, 2T2R MIMO technology
Aerial
Antenna
External detachable
Antenna Qty
2
Compatible Slots
1 x PCI Express x1
Low-profile bracket
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA, WPA2
FCC, RoHS
1.8 cm
12 cm
7.5 cm
15 g
-10 °C
70 °C
5 - 95%
8G47 StarTech.com USB 150Mbps Mini Wireless N Network Adapter - 802.11n/g 1T1R In Stock £13.16
