StarTech.com MST Hub - mDP to 2x DP
Quicklinx: BCN5WS00 Mfr#: MSTMDP122DP
18 in stock
£49.45 ex VAT
£59.34 inc VAT
Use this multi-stream transport hub to connect two DP monitors to a single mDP 1.2 port. This MST hub lets you connect two monitors to your Mini DisplayPort (mDP) 1.2 equipped Windows tablet, laptop or desktop. It's USB powered, so the only thing you'll need to operate the hub is your computer.
The hub has been rigorously tested to ensure compatibility with the Microsoft Surface Pro 4, Surface Pro 3 and Surface Book.
The newest generations of computers are more portable than ever, which often means that you're left with fewer video outputs and smaller integrated screens. This MST hub solves both of these problems by letting you connect two additional displays to your computer, which makes multitasking much easier.
With the MST hub, you can use DisplayPort video adapters and cable adapters that enable you to connect HDMI, VGA or DVI displays. This ensures your MST hub will be compatible with virtually any television, monitor or projector. The hub is VESA and DisplayPort certified to support mDP 1.2 enabled systems, for seamless integration with your existing video equipment.
Using the MST hub, you can extend your desktop onto additional monitors and stream independent content to each display giving you the freedom to multitask and increase your productivity. You can also mirror the same image onto multiple displays for remote viewing applications such as digital signage.
MST technology uses your existing video card to minimize the use of system resources while delivering Ultra HD 4K resolutions. This unprecedented performance makes MST perfect for high-resolution applications such as graphic design, gaming and medical imaging.
Note: When using a DisplayPort 1.1 video card the MST hub will act as a splitter, automatically mirroring your video source across all displays. Resolution limitations apply.
StarTech.com Mini DisplayPort MST Hub - Mini DisplayPort to DisplayPort Multi Monitor Splitter - MST Hub mDP 1.2 to 2x DP (MSTMDP122DP) - video splitter - 2 ports
Video splitter - 2 ports
Subtype
DisplayPort
Ports
2 x DisplayPort
USB powered
5.8 cm x 38.6 cm x 1.4 cm
51 g
3-year warranty
Enclosure Type
Desktop
Subtype
DisplayPort
Ports
2 x DisplayPort
Max Resolution
3840 x 2160 @ 30 Hz
USB powered
2 x DisplayPort , 1 x mini-DisplayPort
FCC, RoHS
5.8 cm
38.6 cm
1.4 cm
51 g
Shipping Width
14.2 cm
Shipping Depth
17.9 cm
Shipping Height
2.7 cm
Shipping Weight
142 g
Limited warranty - 3 years
50 - 90%
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
BCN5 StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £15.22
BCN5 StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £10.18
BCN5 StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £13.88
BCN5 StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 In Stock £15.24
BCN5 StarTech.com Multi Stream Transport Hub – DisplayPort 1.2 to Triple Head DisplayPort MST Hub In Stock £72.46
BCN5 StarTech.com Multi Stream Transport Hub – Mini DisplayPort 1.2 to Triple Head DisplayPort MST Hub In Stock £81.21
BCN5 StarTech.com MST Hub - mDP to 2x DP In Stock £49.45
BCN5 StarTech.com MST Hub - 4-Port DisplayPort In Stock £120.91
BCN5 StarTech.com MST Hub - mDP to 4x DP In Stock £99.35
Price Range Ex VAT: 0 - 50
