Connect your HDMI monitor or HDTV to a DisplayPort equipped computer. The StarTech.com DisplayPort to HDMI adapter lets you connect an HDMI-enabled video display to a DisplayPort video source (e.g.DisplayPort video cards, etc.), eliminating the expense of having to upgrade your display for DisplayPort compatibility.
This adapter supports display resolutions of up to 1920x1200 allowing you to take full advantage of HDMI video capability.
DP2HDMI is a passive adapter cable that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
This adapter allows for audio pass-through if supported by the video source. Please review the video source manual to confirm support.
Reliable Connectivity
This adapter provides a stable connection between DisplayPort and HDMI, ensuring consistent signal transmission for a smooth viewing experience. -
Universal Compatibility
Designed with a 20 pin DisplayPort connector and a 19-pin HDMI Type-A connector, this adapter works with a wide range of devices and displays.
- StarTech.com DisplayPort to HDMI Adapter - 1920 x 1200 - DP to HDMI Converter - Plug and Play DisplayPort to HDMI Dongle (DP2HDMI) - adapter - DisplayPort / HDMI - 24 cm
- Cable
- Adapter - DisplayPort / HDMI
- Length
- 24 cm
- Black
- Connector
- DisplayPort - male
- Connector (Second End)
- HDMI - female
- 3-year warranty
- Designed For
- P/N: DPPNLFM3, DPPNLFM3PW, MST14DP123DP, MSTCDP122DP, MSTCDP123DP, MSTDP122DP, MSTDP123DP, MSTDP124DP, MSTMDP122DP, MSTMDP123DP, MSTMDP124DP, SV231DPU, SV231QDPU34K, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE
- Cable Type
- Adapter
- Interface Supported
- Length
- 24 cm
- Black
- Connector
- 20 pin DisplayPort - male
- 19 pin HDMI Type A - female
- Limited warranty - 3 years
- Designed For
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £7.92 |
StarTech.com DisplayPort to HDMI Video Adapter Converter | In Stock | £11.80 |
StarTech.com DisplayPort to HDMI Video Adapter Converter - M/F | In Stock | £10.81 |
StarTech.com DisplayPort to DVI Video Adapter Converter | In Stock | £9.22 |
StarTech.com DisplayPort to HDMI Video Adapter Converter | In Stock | £14.95 |
StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - M/F | In Stock | £8.02 |
StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F | In Stock | £10.00 |
StarTech.com HDMI or DVI to DisplayPort Active Converter | In Stock | £56.09 |
StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £7.74 |
StarTech.com 3 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black | In Stock | £12.06 |
StarTech.com 10 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 Black | In Stock | £18.85 |
StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £6.78 |
StarTech.com DisplayPort to HDMI 4K Audio / Video Converter – DP 1.2 to HDMI Active Adapter | In Stock | £21.80 |
StarTech.com 3ft DP to HDMI cable - 4K | In Stock | £13.67 |
StarTech.com 6 ft DP to HDMI cable - 4K | In Stock | £15.82 |
StarTech.com DisplayPort to HDMI - 4K | In Stock | £13.27 |
StarTech.com HDMI to DisplayPort Converter - 4K | In Stock | £36.91 |
StarTech.com 5m DisplayPort to HDMI Cable - 4K | In Stock | £20.76 |
StarTech.com 3m DisplayPort to HDMI Cable - 4K | In Stock | £18.39 |
StarTech.com DisplayPort to HDMI - 4K 60Hz | In Stock | £21.76 |
