StarTech.com DisplayPort to VGA Video Adapter Converter
Quicklinx: 68KTWS00 Mfr#: DP2VGA
Hurry, only 3 left in stock!
£20.93 ex VAT
£25.11 inc VAT
The StarTech.com DP2VGA DisplayPort to VGA adapter lets you connect a VGA computer monitor to a DisplayPort video card or other DisplayPort source, eliminating the expense of upgrading the monitor for compatibility. The DP to VGA adapter uses an integrated chip to provide an active digital to analog conversion.
StarTech.com DisplayPort to VGA Adapter - 1920x1200 - Active DP to VGA Video Converter - Plug and Play DP to VGA Connector (DP2VGA) - display adapter - 25 cm
Display adapter
Latched
Length
25 cm
Connector
DisplayPort - male
Connector (Second End)
HD-15 (VGA) - female
FCC
3-year warranty
P/N: DK30C2DAGPD, DPPNLFM3, DPPNLFM3PW, MST14DP123DP, MSTDP122DP, MSTDP123DP, MSTMDP122DP, MSTMDP123DP, SP123DP, SV231DPU, TB32DP14, TB32DP2T, TB3DK2DPM2, TB3DOCK2DPPD, TB3DOCK2DPPU
Display adapter
Latched
Length
25 cm
Connector
20 pin DisplayPort - male
15 pin HD D-Sub (HD-15) - female
FCC
3-year warranty
68KT StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £20.93
68KT StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - M/F In Stock £8.17
68KT StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £16.80
68KT StarTech.com 3 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £17.11
68KT StarTech.com 6 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £19.06
68KT StarTech.com 10 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £20.32
68KT StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 In Stock £15.08
68KT StarTech.com DP to VGA Adapter with Audio In Stock £9.10
68KT StarTech.com DisplayPort to VGA Adapter - 1920x1200 In Stock £62.44
