Use this multi-stream transport hub to connect four DP monitors to a single DP 1.2 port. This MST hub lets you connect four monitors to your DisplayPort (DP) 1.2 equipped Windows laptop or desktop.
The newest generations of computers are more portable than ever, which often means that you're left with fewer video outputs and smaller integrated screens. This MST hub solves both of these problems by letting you connect four additional displays to your computer, which makes multitasking much easier.
With the MST hub, you can use DisplayPort video adapters and cable adapters that enable you to connect HDMI, VGA or DVI displays. This ensures your MST hub will be compatible with virtually any television, monitor or projector. This MST hub is VESA and DisplayPort certified to support DP 1.2 enabled systems, for seamless integration with your existing video equipment.
Using the MST hub, you can extend your desktop onto additional monitors and stream independent content to each display giving you the freedom to multitask and increase your productivity. You can also mirror the same image onto multiple displays for remote viewing applications such as digital signage.
MST technology uses your existing video card to minimize the use of system resources while delivering Ultra HD 4K resolutions. This unprecedented performance makes MST perfect for high-resolution applications such as graphic design, gaming and medical imaging.
Note: When using a DisplayPort 1.1 video card the MST hub will act as a splitter, automatically mirroring your video source across all displays. Resolution limitations apply.
The MSTDP124DP supports plug-and-play installation for a hassle-free setup.
- StarTech.com 4 Port DisplayPort MST Hub - DP 1.2 to 4x DP MST Hub - DisplayPort Multi Monitor Splitter - 4 Port MST Hub (MSTDP124DP) - video splitter - 4 ports
- Video splitter - 4 ports
- Subtype
- DisplayPort
- Ports
- 4 x DisplayPort
- Power
- AC 120/230 V
- 20 cm x 11 cm x 2 cm
- 95 g
- Black
- 3-year warranty
- Designed For
- P/N: SV231DPU34K, SVA5N3NEUA
- Enclosure Type
- Desktop
- Subtype
- DisplayPort
- Ports
- 4 x DisplayPort
- Max Resolution
- 3840 x 2160 @ 30 Hz
- 4 x DisplayPort , 1 x DisplayPort
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Black
- FCC, RoHS
- 20 cm
- 11 cm
- 2 cm
- 95 g
- Limited warranty - 3 years
- 0 °C
- 45 °C
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Designed For
StarTech.com DisplayPort to DVI Video Adapter Converter | In Stock | £15.63 |
StarTech.com DisplayPort to HDMI Video Adapter Converter | In Stock | £15.05 |
StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M | In Stock | £33.86 |
StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M | In Stock | £27.03 |
StarTech.com DisplayPort to VGA Video Adapter Converter | In Stock | £22.41 |
StarTech.com DisplayPort to DVI Video Adapter Converter | In Stock | £10.18 |
StarTech.com DisplayPort to HDMI Video Adapter Converter | In Stock | £12.35 |
StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £14.06 |
StarTech.com DisplayPort to DVI Active Adapter | In Stock | £22.04 |
StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 | In Stock | £15.24 |
StarTech.com Multi Stream Transport Hub – DisplayPort 1.2 to Triple Head DisplayPort MST Hub | In Stock | £72.46 |
StarTech.com Multi Stream Transport Hub – Mini DisplayPort 1.2 to Triple Head DisplayPort MST Hub | In Stock | £80.21 |
StarTech.com MST Hub - mDP to 2x DP | In Stock | £49.45 |
StarTech.com MST Hub - 4-Port DisplayPort | In Stock | £120.91 |
StarTech.com MST Hub - mDP to 4x DP | In Stock | £99.35 |
