StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M
Quicklinx: 68KRWS00 Mfr#: DP2DVIMM10
Type: DisplayPort
Length: 3m
14 In Stock
£21.26 ex VAT
£25.51 inc VAT
Connect your DVI monitor to a DisplayPort equipped computer using a single cable. The DP2DVIMM10 DisplayPort to DVI (M-M) video converter cable lets you connect a DVI capable display to a DisplayPort video card/source using a single cable. The cable provides a connection distance of 10ft and features a male DVI connector and a male DisplayPort connector.
The DisplayPort/DVI video converter cable supports high bandwidth video transmissions, easily delivering monitor resolutions up to 1920x1200 or HDTV resolutions up to 1080p - allowing you to take full advantage of your DVI capable display, while using a cutting edge DisplayPort video source.
DP2DVIMM10 is a passive adapter cable that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
  • Durable construction
    The cable is equipped with nickel-plated connectors that enhance durability and reduce wear over time, ensuring reliable performance across multiple uses.
  • Versatile connectivity
    This adapter cable connects DisplayPort devices to digital DVI displays, allowing for integration with various setups and enhancing compatibility with existing technology.
StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M (DP2DVIMM10) - DisplayPort cable - 3 m
DisplayPort cable
Length
3 m
Connector
DisplayPort - male
Connector (Second End)
DVI-D - male
FCC, RoHS
3-year warranty
P/N: DPPNLFM3, DPPNLFM3PW
DisplayPort cable
Plated Connector
Nickel
Length
3 m
Connector
20 pin DisplayPort - male
24+1 pin digital DVI - male
FCC, RoHS
3-year warranty
68KR StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £8.54
68KR StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M In Stock £21.26
68KR StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M In Stock £21.83
68KR StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £9.00
68KR StarTech.com 6 ft DisplayPort to DVI Cable - M/M In Stock £5.59
68KR StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - M/F In Stock £8.17
68KR StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F In Stock £8.51
68KR StarTech.com DisplayPort to DVI Active Adapter In Stock £20.81
68KR StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female In Stock £9.71
68KR StarTech.com DisplayPort to DVI Dual Link Active Video Adapter Converter - DP to DVI-D - 2560x1600 In Stock £25.81
68KR StarTech.com 3 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black In Stock £11.84
68KR StarTech.com 10 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 Black In Stock £18.47
68KR StarTech.com 3 ft DisplayPort to DVI Active Adapter Converter Cable – DP to DVI 2560x1600 – Black In Stock £18.62
68KR StarTech.com 6 ft DisplayPort to DVI Active Adapter Converter Cable – DP to DVI 2560x1600 – Black In Stock £21.04
68KR StarTech.com 3ft DP to DVI Converter Cable In Stock £14.57
68KR StarTech.com mDP to Dual-Link DVI Adapter In Stock £17.48
Type: DisplayPort
Length: 3m
