StarTech.com DisplayPort to DVI Video Adapter Converter
Quicklinx: 6NZNWS00 Mfr#: DP2DVI2
16 In Stock
£10.86 ex VAT
£13.03 inc VAT
Connect your DVI monitor to a DisplayPort equipped computer. The StarTech.com DP2DVI2 DVI/DisplayPort adapter supports display resolutions of up to 1920x1200 allowing you to take full advantage of single link DVI capability. DP2DVI2 is a passive adapter that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
StarTech.com DisplayPort to DVI-D Adapter - 1920x1200 - Passive DVI Video Converter with Latching DP Connector (DP2DVI2) - DisplayPort adapter - 15.2 cm
DisplayPort adapter
Length
15.2 cm
Connector
DisplayPort - male
Connector (Second End)
DVI-I - female
FCC, RoHS
3-year warranty
P/N: DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK30CH2DEP, DK30CH2DEPUE, DK31C3HDPD, DK31C3HDPDUE, MST14DP123DP, MSTCDP122DP, MSTCDP123DP, MSTDP122DP, MSTDP123DP, MSTDP124DP, MSTMDP122DP, MSTMDP123DP, MSTMDP124DP, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE
DisplayPort adapter
Length
15.2 cm
Connector
20 pin DisplayPort - male
24+5 pin combined DVI - female
FCC, RoHS
3-year warranty
P/N: DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK30CH2DEP, DK30CH2DEPUE, DK31C3HDPD, DK31C3HDPDUE, DVIDDMM1, DVIDDMM10M, DVIDDMM25, DVIDDMM2M, DVIDDMM3M, DVIDDMM5M, MST14DP123DP, MSTCDP122DP, MSTCDP123DP, MSTDP122DP, MSTDP123DP, MSTDP124DP, MSTMDP122DP, MSTMDP123DP, MSTMDP124DP, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE
6NZN StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £9.28
6NZN StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M In Stock £31.26
6NZN StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M In Stock £23.57
6NZN StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £10.86
6NZN StarTech.com 6 ft DisplayPort to DVI Cable - M/M In Stock £16.91
6NZN StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - M/F In Stock £9.31
6NZN StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F In Stock £13.51
6NZN StarTech.com DisplayPort to DVI Active Adapter In Stock £22.91
6NZN StarTech.com DisplayPort to DVI Dual Link Active Video Adapter Converter - DP to DVI-D - 2560x1600 In Stock £65.80
6NZN StarTech.com 3 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black In Stock £13.67
6NZN StarTech.com 10 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 Black In Stock £21.85
6NZN StarTech.com 6 ft DisplayPort to DVI Active Adapter Converter Cable – DP to DVI 2560x1600 – Black In Stock £23.85
6NZN StarTech.com 3ft DP to DVI Converter Cable In Stock £16.71
6NZN StarTech.com mDP to Dual-Link DVI Adapter In Stock £93.65
