This DisplayPort to HDMI MST Hub drives two 4K 60Hz HDMI monitors from a DisplayPort enabled Windows device.
Multi-tasking Made Easy
This DisplayPort to HDMI video splitter allows you to connect up to two additional displays in extended or mirror mode. Connecting two independent 4K 60Hz displays creates high-performance workstations for users in your organization, enabling easier multi-tasking, resulting in increased productivity. -
4K at 60Hz and HDR
Native support for MST, on any Windows device, enables an easy set up. This MST Hub separates the single stream into two independent signals, one for each HDMI enabled display. Support for High Dynamic Range (HDR) offers increased contrast, brightness, colors, and greater luminosity. -
Hassle-Free Setup
MST offers an easy setup, by natively working on any Windows device. Plug-and-play installation with no drivers or software required. A 12in (30cm) attached cable provides options for flexible installation configurations, reducing the amount of strain on ports and connectors. Additionally, this dual-monitor splitter is USB powered (USB Cable included). MST14DP122HD is backed by a StarTech.com 3-year warranty, and a lifetime of free, North American based, multilingual technical support.
- StarTech.com DP to Dual HDMI MST HUB, Dual HDMI 4K 60Hz, DisplayPort Multi Monitor Adapter with 1ft (30cm) Cable, DP 1.4 Multi Stream Transport Hub, DSC | HBR3, DP to 2x HDMI Ports - DP to HDMI Splitter (MST14DP122HD) - adapter - DisplayPort / HDMI
- Cable
- Adapter - DisplayPort / HDMI
- Max Output Resolution
- 3840 x 2160 - 60 Hz
- Grey
- Connector
- DisplayPort - male
- Connector (Second End)
- 2 x HDMI - female
- DisplayPort 1.4
- Display Stream Compression (DSC), HBR3 audio support, Multi Stream Transport (MST), 7.1 channel Surround Sound
- 3-year warranty
- Cable Type
- Adapter
- Interface Supported
- DisplayPort 1.4
- Grey
Adapters & Converters
- 3840 x 2160
- Refresh Rate
- 60 Hz
- OS Required
- Microsoft Windows 10 / 11
- Connector
- 20 pin DisplayPort - male
- 2 x 19 pin HDMI Type A - female
- Included Accessories
- USB power cable
- RoHS
- 10.5 cm
- 4.3 cm
- 1.4 cm
- 53 g
- Shipping Width
- 14.2 cm
- Shipping Depth
- 17 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 110 g
- Limited warranty - 3 years
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £7.80 |
StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £7.74 |
StarTech.com 1m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £6.69 |
StarTech.com 1m 3ft Premium HDMI 2.0 Cable | In Stock | £11.32 |
StarTech.com 2m 6ft Premium HDMI 2.0 Cable | In Stock | £16.00 |
StarTech.com 2m/6.6 ft Premium High Speed HDMI Cable with Ethernet | In Stock | £18.40 |
StarTech.com 6ft Premium Certified HDMI 2.0 | In Stock | £12.98 |
StarTech.com 2-Port DisplayPort MST Hub | In Stock | £27.87 |
