StarTech.com 3-Port DisplayPort MST Hub
Quicklinx: HDGVWS00 Mfr#: MST14DP123HD
Type: Display port
Interface: [N/A]
Speed: [N/A]
Ports: 3
Form Factor: External
Hurry, only 3 left in stock!
£66.26 ex VAT
£79.51 inc VAT
3-Port MST Hub, DisplayPort to Triple HDMI Monitors, 4K 60Hz, DP 1.4 Multi-Monitor Video Adapter with 1ft (30cm) Built-in Cable, USB Powered, Windows Only - Multi-Stream Transport Hub (MST14DP123HD).
  • Drive triple 4K 60 Hz displays with HDR
    Multi-Stream Transport (MST) technology combines multiple video signals into a single output signal/stream. This MST Hub separates the single input stream into three independent signals, one for each HDMI-enabled display. Support for High Dynamic Range (HDR) facilitates enhanced contrast, brightness, color, and luminosity.
  • Multitasking made easy
    Configure the triple-HDMI displays in extended or mirrored mode. Create a high-performance workstation by adding three independent 4K 60 Hz displays. This empowers increased multi-tasking across your organization, resulting in increased productivity.
  • Driverless for rapid deployment and seamless user setup experience
    This MST Hub achieves maximum performance with Windows desktops featuring Intel 12th generation (and later) processors, or dedicated graphics cards with DisplayPort 1.4 output ports and DSC support. Plug-and-play installation with no drivers or software required. The 12in (30cm) built-in DisplayPort cable provides options for flexible installation configurations, reducing the amount of strain on the port and connector. Additionally, this triple-monitor splitter is USB Powered and includes a 20inch (50cm) USB Micro-B power cable.
StarTech.com 3-Port MST Hub, DisplayPort to Triple HDMI Monitors, 4K 60Hz, DP 1.4 Multi-Monitor Video Adapter with 1ft (30cm) Built-in Cable, USB Powered, Windows Only - Multi-Stream Transport Hub (MST14DP123HD) - video/audio switch - 3 ports
Video/audio switch - 3 ports
Subtype
HDMI
Ports
3 x HDMI
MST support, USB powered, DSC, HDR support, 7.1 channel audio support, triple display support, Synaptics VMM5310 chipset, IT6563FN chipset, plastic housing, wide screen supported
HDCP 2.2
4.3 cm x 10.5 cm x 1.4 cm
Space grey
Microsoft Windows 10 / 11
3-year warranty
Enclosure Type
Desktop
Subtype
HDMI
Ports
3 x HDMI
Max Resolution
4096 x 2160 @ 60 Hz
HDCP 2.2
3 x HDMI output , 1 x DisplayPort input , 1 x micro-USB (power only)
Space grey
1 x DisplayPort cable - 30 cm
DisplayPort 1.4, DisplayPort 1.2, RoHS, WEEE, REACH, DOC, DSC, High Bit Rate 3 (HBR3)
4.3 cm
10.5 cm
1.4 cm
Shipping Width
14.2 cm
Shipping Depth
17 cm
Shipping Height
3 cm
Shipping Weight
115 g
Limited warranty - 3 years , Technical support - assistance - lifetime
0 - 95% RH (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
HDGV StarTech.com 3ft (1m) HDMI 2.1 Cable 8K - Certified Ultra High Speed HDMI In Stock £16.48
HDGV StarTech.com 6ft (2m) HDMI 2.1 Cable 8K - Certified Ultra High Speed HDMI In Stock £20.48
HDGV StarTech.com 10ft Ultra High Speed HDMI 2.1 In Stock £23.74
Type: Display port
Interface: [N/A]
Speed: [N/A]
Ports: 3
