Premium Certified HDMI 2.0 Cable - 4K 60Hz - 6.6 ft. (2 m)
This 6.6 ft. (2 m) Premium High Speed HDMI 2.0 Certified Cable withstands the daily demands of connecting your HDMI devices. Tested to endure strenuous wear and tear, this durable cable is a must-have for both business and consumer applications.
Experience the latest that HDMI 2.0 has to offer
This high performance 4K cable supports resolutions of up to 4K at 60Hz (3840x2160p) and bandwidths of up to 18Gbps. It also supports HDR10 (High Dynamic Range) and Dolby Vision for higher contrast ratio and vivid colors.
Plus, ARC (Audio Return Channel) has up to 32 uncompressed 5.1 and 7.1 digital audio channels to support DTS-HD Master Audio , DTS:X , Dolby TrueHD, Dolby Atmos for high quality sound.
With high resolutions, increased speeds, sharper images, and crystal-clear audio, you can expect an enhanced video experience. The cable is guaranteed to provide the very best HDMI 4K performance available today. It's the perfect cable for creating the ultimate home theater or for providing lifelike digital signage.
This cable works with all 4K ready devices and is also backward compatible with previous HDMI specifications.
Provide superior connections with Premium High Speed certification
The cable has undergone rigorous compliance testing and is certified by an HDMI Authorized Test Center to ensure it supports the high bandwidth enabled features it promises. An EMI test is also performed to ensure the cable minimizes interference with wireless signals.
Cable Key Features
Aluminum-mylar foil with braided shielding improve EMI protection
Long lasting flexible TPE jacket & strain relief (TPE is non-toxic & halogen free for environmental sustainability)
Connector Key Features
Corrosion-free gold-plated connectors ensure premium video quality & enhanced reliability
Tested to withstand 10,000+ insertions
The HDMMV2M is backed by StarTech.com's Lifetime Warranty.
Experience what HDMI 2.0 has to offer
This high performance 4K cable supports resolutions of up to 4K at 60Hz and extended bandwidths. It also supports HDR10 (High Dynamic Range) and Dolby Vision for higher contrast ratio and vivid colors. Plus, ARC (Audio Return Channel) has up to 32 uncompressed 5.1 and 7.1 digital audio channels to support DTS-HD Master Audio, DTS: X, Dolby TrueHD, Dolby Atmos for high quality sound. With high resolutions, increased speeds, sharper images, and crystal-clear audio, you can expect an enhanced video experience. The cable is guaranteed to provide the very best HDMI 4K performance available today. It's the perfect cable for creating the ultimate home theater or for providing lifelike digital signage. This cable works with all 4K ready devices and is also backward compatible with previous HDMI specifications. -
Provide superior connections with premium high speed certification
The cable has undergone rigorous compliance testing and is certified by an HDMI authorized test center to ensure it supports the high bandwidth enabled features it promises. An EMI test is also performed to ensure the cable minimizes interference with wireless signals.
 - StarTech.com 6ft (2m) Premium Certified HDMI 2.0 Cable with Ethernet, High Speed Ultra HD 4K 60Hz HDMI Cable HDR10, ARC, HDMI Cord For Ultra HD Monitors, TVs, Displays, w/ TPE Jacket - Durable HDMI Video Cable (HDMMV2M) - HDMI cable with Ethernet - 2 m
- Cable
 - Premium High Speed - HDMI cable with Ethernet
- Technology
 - Shielded
- American Wire Gauge (AWG)
 - 30
- Length
 - 2 m
 - Grey, black
- Connector
 - HDMI - male
- Connector (Second End)
 - HDMI - male
 - Passive cable, 4K60Hz (3840 x 2160) support
 - Limited lifetime warranty
- Cable Type
 - Premium High Speed - HDMI cable with Ethernet passive, 4K60Hz (3840 x 2160) support
- Technology
 - Shielded
 - 30
- Jacket Material
 - Thermoplastic elastomer (TPE)
- Shielding Material
 - Aluminum mylar foil with braid
- Length
 - 2 m
- Plated Connector
 - Gold
 - Audio Return Channel (ARC), Dolby TrueHD support, Dolby DTS-HD Master Audio support, Dolby Atmos support, support HDR10, Dolby DTS 5.1 support, Dolby DTS:X support, 3D ready, colourimetry BT.2020 support, 18 Gbps data rate, Dolby DTS 7.1 support, strain relief, outer diameter 6mm
 - Grey, black
- Connector
 - 19 pin HDMI Type A - male
 - RoHS
- Shipping Width
 - 22 cm
- Shipping Depth
 - 20 cm
- Shipping Height
 - 4 cm
- Shipping Weight
 - 100 g
 - Limited warranty - lifetime
                        StarTech.com 13ft/4m Premium Certified HDMI 2.0 Cable | In Stock | £17.11 |
                        StarTech.com 16ft/5m Premium Certified HDMI 2.0 Cable | In Stock | £17.69 |
                        StarTech.com Triple Monitor Desk Mount | In Stock | £173.71 |
                        StarTech.com Triple Monitor Desk Mount | In Stock | £164.96 |
                        StarTech.com Crossbar Dual Monitor Stand | In Stock | £85.54 |
