Brand
StarTech.com mSATA SSD to 2.5in SATA Adapter Converter
Quicklinx: 9CS8WS00 Mfr#: SAT32MSAT257
£18.92 ex VAT
£22.70 inc VAT
Convert an mSATA SSD into a 7mm high 2.5in SATA 6Gbps Open Frame SSD. Vastly increase system performance by adding the speed of an mSATA SSD in any 2.5" SATA application, with the SAT32MSAT257 mSATA to SATA adapter.
Utilize the full potential of your SATA III controller, with an mSATA SSD reducing your DATA transfer bottle neck with file transfer speeds up to 6 Gbps. mSATA SSDs also save you money by reducing your power consumption over regular platter drives.
Help protect the health of your drive with an open frame design ensuring maximum heat dissipation.
StarTech.com mSATA SSD to 2.5in SATA Adapter Converter - mSATA to SATA Adapter for 2.5in bay with Open Frame Bracket and 7mm Drive Height (SAT32MSAT257) - storage controller - SATA 6Gb/s - SATA 6Gb/s
Storage controller - internal
Bus Type
SATA 6Gb/s
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive, solid state drive
Channel Qty
1
7 cm x 10 cm x 0.7 cm
100 g
P/N: BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET425F, SATDOCK5U3ER, SATERASER4, SDOCK1EU3P, SDOCK1EU3P2, SDOCK4U313, SDOCKU313, SDOCKU313E, USB312SAT3, USB31C2SAT3, USB31CSAT3CB
Host Bus
SATA 6Gb/s
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Channel Qty
1
1 x SATA 6Gb/s - SATA power
1 - 52 pin mini-SATA
Mounting Kit
Included
FCC, RoHS
7 cm
10 cm
0.7 cm
100 g
-40 °C
85 °C
9CS8 StarTech.com 24" Serial ATA Cable In Stock £3.89
9CS8 StarTech.com 18" Serial ATA Cable w/R Angle In Stock £5.00
9CS8 StarTech.com 18in SATA Serial ATA Data and Power Combo Cable In Stock £6.06
9CS8 StarTech.com 18in SATA Serial ATA Cable In Stock £3.64
9CS8 StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter In Stock £3.65
9CS8 StarTech.com 24in SATA to Right Angle SATA Serial ATA Cable In Stock £3.89
9CS8 StarTech.com 12in Latching SATA Cable In Stock £3.66
9CS8 StarTech.com 2.5in SATA Hard Drive to 3.5in Drive Bay Mounting Kit In Stock £4.38
9CS8 StarTech.com 12in SATA Serial ATA Cable In Stock £3.28
9CS8 StarTech.com 6in SATA to LP4 Power Cable Adapter - F/M In Stock £4.70
9CS8 StarTech.com 18in SATA to Left Angle SATA Serial ATA Cable - F/F In Stock £4.56
9CS8 StarTech.com 8in Latching SATA to SATA Cable - F/F In Stock £3.79
9CS8 StarTech.com 6in SATA to Left Angle SATA Serial ATA Cable In Stock £3.56
9CS8 StarTech.com 2.5in SATA to Mini SATA SSD Adapter Enclosure In Stock £36.64
9CS8 StarTech.com 18in SATA to Left Side Angle SATA Serial ATA Cable In Stock £3.08
9CS8 StarTech.com Dual 2.5" to 3.5" HDD Bracket for SATA Hard Drives - 2 Drive 2.5" to 3.5" Bracket In Stock £8.09
9CS8 StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter In Stock £17.85
9CS8 StarTech.com mSATA SSD to 2.5in SATA Adapter Converter In Stock £18.92
9CS8 StarTech.com 40-Pin IDE PATA to SATA Adapter Converter for HDD/SSD/ODD In Stock £7.68
9CS8 StarTech.com M.2 to U.2 Adapter In Stock £25.27
9CS8 StarTech.com x8 Dual M.2 PCI Express SSD Adapter - PCIe 3.0 for PCIe NVMe In Stock £146.22
Stock Status: In stock
