StarTech.com Monitor Riser - Large (19.7")
Quicklinx: CRYDWS00 Mfr#: MONSTADJDL
Device Type: Monitor
Type: Monitor Riser
Device Screen Size: 13 - 32
Colour: Black
More than 50 In Stock
£24.42 ex VAT
£29.30 inc VAT
Free up desk space and work in greater comfort with this adjustable monitor stand. Raise your monitor to eye level for more comfortable viewing, while saving desktop space. This sturdy height-adjustable monitor stand supports a monitor up to 32" in size and up to 22 lb. (10 kg) in weight, and provides a large storage space underneath the riser. It features stackable columns that sit neatly on your desk or table, leaving enough space to fit virtually any laptop. It even has a drawer to hold office supplies.
Create a workstation that works best for your needs. This monitor riser features modular columns, made of stackable components that snap together easily to raise or lower the height of the monitor stand. You can choose between three different height settings, with a maximum height of 6.6" (168 mm). You can also reconfigure the columns at any time to adjust the height of the stand.
The monitor stand makes it easy to work free from clutter. The work surface raises your monitor to a comfortable height to create a more ergonomic environment. The large monitor riser, 19.7" x 13" (500 x 330 mm), provides ample storage area underneath. You can also use the work platform to hold a printer, to free up counter space.
In the area under the stand, between the columns, there is large storage area with plenty of space to put your laptop and personal items. A convenient drawer gives you an easily accessible place to keep pens and other small office supplies. There is even a front slot that will hold most tablets and phones, so your important devices are close at hand when you need them.
The monitor stand is easy to assemble, so you'll be up and running in no time. The non-skid base on the columns protects your work surface from scratches or scuffs and ensures your monitor rests securely while you work. A built-in cable manager routes cables neatly to keep them out of view.
  • Adjust your monitor to the desired height
  • Maximize desk space and reduce clutter
    The monitor stand makes it easy to work free from clutter. The work surface raises your monitor to a comfortable height to create a more ergonomic environment. The large monitor riser, 19.7" x 13", provides ample storage area underneath. You can also use the work platform to hold a printer, to free up counter space.
  • Simple setup
StarTech.com Adjustable Monitor Riser - Large - Drawer - Monitors up to 32"- Adjustable Height - Desk Monitor Stand (MONSTADJDL) stand - for Monitor - black
Stand
Mounting Components
Stand surface, 8 small risers, 4 large risers
33 cm x 50 cm x 16.8 cm
Adjustments
Recommended Use
Monitor
Recommended Display Size
13"-32"
Max Load Weight
10 kg
Material
Plastic
5-year warranty
33 cm
50 cm
16.8 cm
Material
Plastic
AV Furniture
Stand
Mounting Components
Recommended Use
Monitor
13"-32"
Adjustments
Max Load Weight
10 kg
Details
Integrated drawer
Limited warranty - 5 years
CRYD StarTech.com Sit-to-Stand Workstation In Stock £121.36
CRYD StarTech.com Monitor Riser with Drawer In Stock £24.85
CRYD StarTech.com Monitor Riser - Large (19.7") In Stock £24.42
CRYD StarTech.com USB-C Multiport Adapter - SD - Power Delivery - 4K HDMI - GbE - 2x USB 3.0 In Stock £70.33
CRYD StarTech.com Under Desk Keyboard Tray In Stock £53.36
CRYD StarTech.com Monitor Riser Stand In Stock £41.78
CRYD StarTech.com 15in Laptop Privacy Screen - Matte or Glossy - 16:9 Ratio In Stock £32.40
CRYD StarTech.com 13in Laptop Privacy Screen - 16:10 Aspect Ratio In Stock £33.45
CRYD StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy In Stock £54.54
CRYD StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £61.12
CRYD StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £77.59
Type: Monitor Riser
Colour: Black
