StarTech.com Monitor Riser with Drawer
Quicklinx: CRYCWS00 Mfr#: MONSTADJD
Accessory Type: Stand
£24.62 ex VAT
£29.54 inc VAT
Free up desk space and work in greater comfort with this adjustable monitor stand. Raise your monitor to eye level for more comfortable viewing, while saving desktop space. You can set this sturdy height-adjustable monitor stand on your desk or table, to support a monitor up to 32" in size and up to 22 lb. (10 kg) in weight. It features stackable columns that sit neatly on your desk or table, leaving enough space under your monitor to fit a small laptop. It even has a drawer to hold office supplies.
Create a workstation that works best for your needs. This monitor riser features modular columns, made of stackable components that snap together easily to raise or lower the height of the monitor stand. You can reconfigure the columns any time to adjust the height of the stand.
The monitor stand makes it easy to work free from clutter. In the area under the stand, between the columns, there is plenty of space to place a small laptop. A convenient drawer gives you a convenient place to keep pens and other small office supplies. There is even a front slot that will hold most tablets and phones, so your important devices are close at hand when you need them.
The monitor stand is easy to assemble, so you'll be up and running in no time. The non-skid base on the columns protects your work surface from scratches or scuffs, and ensures your monitor rests securely while you work. A built-in cable manager routes cables neatly to keep them out of view.
  • Versatile design
    This stand supports a variety of monitor sizes from 13 inches to 32 inches, making it adaptable for different setups.
  • Integrated storage
    The built-in drawer provides convenient space for keeping office supplies or personal items organized and within reach.
  • Adjustable height
    The height adjustment feature allows users to change the display height to their preferred level, enhancing ergonomic comfort.
  • Sturdy support
    Crafted from durable plastic, this monitor riser can handle weight up to 10 kg, ensuring stability for a variety of monitors.
  • Easy assembly
    Designed for quick and straightforward assembly, the monitor riser can be set up in no time, providing immediate benefit.
StarTech.com Adjustable Monitor Riser - Drawer - Monitors up to 32"- Adjustable Height - Monitor Stand - Computer Monitor Riser (MONSTADJD) stand - for Monitor - black
Stand
Mounting Components
Stand surface, 8 small risers, 4 large risers
33 cm x 43.5 cm x 16.8 cm
Adjustments
1.6 kg
Recommended Use
Monitor
Recommended Display Size
13"-32"
Max Load Weight
10 kg
Material
Plastic
5-year warranty
33 cm
43.5 cm
16.8 cm
1.6 kg
Material
Plastic
AV Furniture
Stand
Mounting Components
Recommended Use
Monitor
13"-32"
Adjustments
Max Load Weight
10 kg
Assembly Required
Details
Integrated drawer
Limited warranty - 5 years
CRYC StarTech.com Sit-to-Stand Workstation In Stock £234.62
CRYC StarTech.com Monitor Riser with Drawer In Stock £24.62
CRYC StarTech.com Monitor Riser - Large (19.7") In Stock £24.31
CRYC StarTech.com USB-C Multiport Adapter - SD - Power Delivery - 4K HDMI - GbE - 2x USB 3.0 In Stock £68.98
CRYC StarTech.com Under Desk Keyboard Tray In Stock £52.06
CRYC StarTech.com Monitor Riser Stand In Stock £40.75
CRYC StarTech.com 15in Laptop Privacy Screen - Matte or Glossy - 16:9 Ratio In Stock £31.60
CRYC StarTech.com 13in Laptop Privacy Screen - 16:10 Aspect Ratio In Stock £32.64
CRYC StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy In Stock £50.12
CRYC StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £58.71
CRYC StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £76.85
CRYC StarTech.com Ergonomic Monitor Riser Stand In Stock £32.89
