StarTech.com Monitor Riser Stand
Quicklinx: F6TCWS00 Mfr#: MONSTND
Accessory Type: Stand
£41.78 ex VAT
£50.13 inc VAT
Create a more ergonomic workspace. This strong and sturdy monitor riser stand lifts your display off of your desk for more comfortable viewing, helping to prevent neck strain. Its attractive silver and black design adds to the aesthetic appeal of your workspace, and creates storage space underneath.
Elevate your display to position your monitor. You can customize the height of the computer monitor riser, adjusting easily to three different heights: 4.9", 5.9" or 6.9" (12.5, 15 or 17.5 cm) off the desk surface.
With a robust 10.5" x 16" steel surface area and an aluminum base, the monitor riser provides a stable platform for a monitor up to 32" with maximum weight capacity of up to 22 lb. (10 kg). You can also use it for your laptop. The non-skid bottom surface of the feet provides a solid grip while protecting your desk surface from scratches and scuff-marks. It's ideal for a variety of desk surfaces including glass-top desks.
Maximize your work space and create a clutter-free area. Store your mouse, phone, and other items underneath the monitor shelf so they are out of view, but not out of reach. You can also use the riser stand to raise your printer, freeing up desk or counter space underneath. The integrated cable management slots keep cables organized and out of view.
With fast and easy setup, you'll be ready to work with the monitor riser within minutes.
  • Sturdy construction
    Made from a combination of aluminum and steel, this monitor riser stand provides a strong and durable platform for your display.
  • Height adjustable
    The stand can be easily adjusted to different heights, allowing users to find the most comfortable viewing angle.
  • Suitable for large displays
    Recommended for monitors up to 32 inches, making it a versatile option for various desktop setups.
  • Organized workspace
    By elevating the monitor, the stand also helps in creating a more organized workspace, freeing up valuable desk space.
  • Easy to assemble
    The monitor riser stand requires minimal assembly, making it a quick and convenient addition to any office setup.
StarTech.com Monitor Riser Stand - For up to 32" Monitor - Height Adjustable - Computer Monitor Riser - Steel and Aluminum (MONSTND) stand - for Monitor
Stand - desktop
40.5 cm x 30.5 cm x 12.5 cm
Adjustments
3.2 kg
Recommended Use
Monitor
Recommended Display Size
32"
Max Load Weight
10 kg
Material
Aluminium, steel
5-year warranty
40.5 cm
30.5 cm
12.5 cm
3.2 kg
Material
Aluminium, steel
AV Furniture
Stand
Recommended Use
Monitor
Placing / Mounting
Desktop
32"
Adjustments
Max Load Weight
10 kg
Assembly Required
Limited warranty - 5 years
F6TC StarTech.com Monitor Riser with Drawer In Stock £24.85
F6TC StarTech.com Monitor Riser - Large (19.7") In Stock £24.53
F6TC StarTech.com 15in Laptop Privacy Screen - Matte or Glossy - 16:9 Ratio In Stock £32.40
F6TC StarTech.com 13in Laptop Privacy Screen - 16:10 Aspect Ratio In Stock £33.45
F6TC StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy In Stock £54.54
F6TC StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £61.12
F6TC StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £77.54
F6TC StarTech.com Ergonomic Monitor Riser Stand In Stock £33.19
