Desk-mount your monitor to save space and increase your productivity. Free up space while creating a more comfortable and productive work environment. This desk-mount monitor arm makes it easy to mount your display above your desk or table and adjust the height with one touch for ideal viewing. Its sleek silver finish enhances the aesthetics of your workspace.
This heavy-duty monitor arm helps you save space on your desk or table surface, by enabling you to securely mount a computer monitor from 13" (330 mm) to up to 32" (813 mm) in size and up to 19.8 lb. (9 kg) in weight. It's ideal for many different office applications, such as healthcare or financial settings, shared workspaces, or when you wish to show your display to clients or colleagues.
The desk-mount monitor arm features a gas-spring cylinder that makes it easy to raise or lower your display. You can also adjust the tension according to the weight of your monitor, so you can re-position the monitor height effortlessly at any time. It provides 13.1" (335 mm) of height adjustment to accommodate a wide range of applications. Easy one-touch height adjustment makes the monitor arm ideal for shared workstations with multiple alternating users, such as hot desks.
The full-motion articulating arm makes it easy to find the right viewing angle. You can swivel your monitor 180 degrees to share your display, while collaborating with others. The articulating arm also supports 180-degree rotation, so it's easy to switch from landscape to portrait orientation, and back again. You can also tilt your screen +90° to -90° for comfortable viewing.
The single-monitor arm is designed to ensure that mounting your VESA compatible monitor is fast and easy. It requires minimal assembly and features a detachable VESA panel that makes it simple to attach or remove your monitor. The monitor arm also offers built-in cable management that helps keep your cables out of sight to create a clean, sleek look.
Mount your Monitor to Save Valuable Space
This heavy-duty aluminum monitor arm helps you save space, by securely mounting a computer monitor from 13" to 34" in size and up to 19.9 lb. (9 kg) in weight. It's ideal for many different office applications, such as healthcare or financial settings, shared workspaces, or when you wish to show your display to clients or colleagues. -
Easy One-Touch Height Adjustment
The single monitor arm provides one-touch height adjustment, with a gas-spring cylinder that makes it easy to raise or lower your display. Adjust the tension according to the weight of your monitor, so you can re-position the monitor height effortlessly. The monitor mount provides 13.1" (335 mm) of height adjustment. -
Adjust your Monitor Easily
The full-motion articulating arm makes it easy to find the right viewing angle. Swivel your monitor 180 degrees to share your display. The articulating arm also supports 180-degree rotation, for landscape or portrait orientation. For comfortable viewing, tilt your screen +90 to -90 degrees. -
Durable Construction and Easy Installation
Made of aluminum, the single monitor mount requires minimal assembly and is easy to install with the desk clamp or grommet mount. A detachable VESA mount panel makes it simple to attach or remove your monitor. Built-in cable management helps keep your cables organized. The ARMPIVOTHD is backed by a StarTech.com 5-year warranty and free lifetime technical support.
 - StarTech.com Desk Mount Monitor Arm, Heavy Duty Ergonomic VESA Monitor Arm, Single Display up to 9kg, Full Motion, Height Adjustable, Articulating, Aluminum, C-Clamp/Grommet, Silver - Small Footprint Design mounting kit - adjustable arm - for LCD display - silver
- Product Type
 - Mounting kit (adjustable arm) - desk-mountable
 - 28.4 cm x 9.6 cm x 52.9 cm
- Lift
 - 17 - 50.5 cm
- Rotation
 - -90° to 90°
- Swivel
 - 180°
- Adjustments
 - Tilt
 - 3.1 kg
- Recommended Use
 - LCD display
- Recommended Display Size
 - 12"-34"
- VESA Mounting Interface
 - 100 x 100 mm, 75 x 75 mm
- Max Load Weight
 - 9 kg
- Material
 - Heavy duty aluminium
 - Silver
 - 2-year warranty
- Designed For
 - P/N: ACCSMNT, MONPROTECT
 - 28.4 cm
 - 9.6 cm
 - 52.9 cm
 - 3.1 kg
- Material
 - Silver
AV Furniture
 - Mounting kit
- Design
 - Adjustable arm
- Recommended Use
 - LCD display
- Placing / Mounting
 - Desk-mountable
- Cable Management
 - Integrated cable management
 - 12"-34"
- Lift
 - 17 - 50.5 cm
- Rotation
 - -90° to 90°
- Swivel
 - 180°
- Adjustments
 - Tilt
- Max Load Weight
 - 9 kg
 - Limited warranty - 2 years
- Designed For
                        StarTech.com Sit-to-Stand Workstation | In Stock | £121.36 |
                        StarTech.com USB-C Multiport Adapter - SD - Power Delivery - 4K HDMI - GbE - 2x USB 3.0 | In Stock | £68.98 |
                        StarTech.com Thin Client Mount - VESA | In Stock | £22.48 |
                        StarTech.com Under Desk Keyboard Tray | In Stock | £52.06 |
                        StarTech.com Desk Mount Monitor Arm - Full Motion - Articulating - Heavy | In Stock | £96.46 |
                        StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy | In Stock | £50.12 |
                        StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £58.71 |
                        StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £75.65 |
                        StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop | In Stock | £7.34 |
                        StarTech.com Monitor Desk Mount, VESA | In Stock | £110.60 |
                        StarTech.com Monitor Desk Mount, VESA | In Stock | £96.01 |
                        StarTech.com Desk Mount Monitor Arm/Max 32" | In Stock | £157.56 |
