This monitor desk mount is designed to support up to a 32-inch ultrawide display. The mechanical spring arm enables a toolless height adjustment range of 7.7 to 20.6in (19.7 to 52.4cm) with effortless one-touch motion. The maximum arm extension is 21in (53.5cm) and the total weight capacity is 22lb (10kg). The monitor arm comes pre-assembled and includes a VESA monitor plate that uses thumb screws to securely mount the monitor quickly and without additional tools. The monitor VESA mounts support +/-30° swivel, +90°/-15° tilt, and 360° screen rotation for portrait or landscape orientation. The computer monitor mount is backed for 10 years. The arms feature a cable management channel along the underside to keep cables out of sight, reducing clutter and contributing to a tidy setup.
Quick and Toolless Installation
The monitor arm comes pre-assembled and includes a VESA monitor plate that uses thumb screws to securely mount the monitor quickly and without additional tools. -
Height Adjustment with One Smooth Motion
The mechanical spring arm enables toolless height adjustment with a range from 7.7 to 20.6in (19.7 to 52.4cm) with effortless one-touch motion. The maximum arm extension is 21in (53.5cm) with a total weight capacity of 22lb (10kg). -
Range of Motion
The monitor's VESA mounts enable support of +/-15° swivel, +90/-15° tilt, and 360° screen rotation for portrait/landscape orientation. -
Cable Management
To maintain an organized workspace, the arms feature a cable management channel along the underside to keep cables out of sight, reducing clutter and contributing to a tidy setup. The monitor mount is TAA-compliant and is backed for 10-years including free lifetime 24/5 multi-lingual technical assistance.
- StarTech.com Desk Mount Monitor Arm, Up To 32" Display, C-Clamp, TAA mounting kit - for Monitor - black - TAA Compliant
- Product Type
- Mounting kit - desk-mountable
- Mounting Components
- Articulating arm, C-clamp
- 12 cm x 60 cm
- Adjustable Height
- 20.2-52.9 cm
- Tilt
- -15° to 90°
- Rotation
- 360°
- Swivel
- -15° to 15°
- Adjustments
- Height, rotation, tilt, swivel, extension
- 3.5 kg
- Recommended Use
- Monitor
- Recommended Display Size
- 17"-27"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 10 kg
- Material
- Plastic, steel
- Black
- TAA Compliant
- Package Content
- 2 bases, 4 x VESA screws, spring arm assembly, VESA monitor mount, cable clip, M3 hex key, M6 hex key
- 10 years warranty
- 12 cm
- 60 cm
- Adjustable Height
- 20.2-52.9 cm
- 3.5 kg
- Material
- Plastic, steel
- Black
- Package Content
AV Furniture
- Mounting kit
- Recommended Use
- Monitor
- Placing / Mounting
- Desk-mountable
- Cable Management
- Cable management channel
- 17"-27"
- Tilt
- -15° to 90°
- Rotation
- 360°
- Swivel
- -15° to 15°
- Adjustments
- Max Load Weight
- 10 kg
- TAA Compliant
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 54.7 cm x 34 cm x 16.4 cm / 3.5 kg
- Limited warranty - 10 years
StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £77.54 |
StarTech.com 24" Monitor Privacy Screen | In Stock | £79.81 |
StarTech.com 27" Monitor Privacy Screen | In Stock | £103.98 |
StarTech.com 25" Monitor Privacy Screen | In Stock | £73.04 |
