More productive than ever. This Dell monitor brings an amazing level of productivity to the work place without sacrificing comfort and convenience.
Purposefully designed for comfort and convenience
With a full range of adjustable features, slim borders and multiple connectivity ports. -
Enhanced viewing experience
Dell ComfortView and flicker-free feature make work less strenuous when viewing vividly clear visuals across an ultrawide viewing angle. -
Reliable and responsible
Get complete piece of mind with Premium Panel Guarantee, Advanced Exchange Service and an eco-friendly design. -
A more seamless workflow
Slim borders create a smoother and less obstructed visual experience when working across multiple monitors. -
Versatility you can count on
Enjoy full adjustability to pivot, tilt, adjust the height, and swivel your monitor to your exact preference. -
More ways to stay connected
Multiple connectivity ports on the bottom and side of the monitor allow you to easily connect to various devices.
- Dell P2317H - LED monitor - Full HD (1080p) - 23"
- LED-backlit LCD monitor - 23"
- Energy Class
- Class A+
- Energy Consumption per Year
- 22 kWh
- Power Consumption (On mode)
- 15 W
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.265 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 4000000:1 (dynamic)
- Response Time
- 6 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC (CIE 1931), 82% NTSC (CIE 1976)
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 53.2 cm x 18 cm x 35.71 cm
- 5.16 kg
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Carbon Footprint
- 493 kg carbon emissions
- EMC, DDC/CI, RoHS
- 3-year warranty
- Bundled Services
- 3 years Advanced Exchange Service
- Display Type
- Energy Class
- Class A+
- 22 kWh
- Diagonal Size
- 23"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.265 mm
- Pixel Per Inch
- 96
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- OSD Languages
- Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
- Ultra wide viewing angle, LED edgelight system, stand lock, Flicker Free technology, BFR/PVC-free, Energy Gauge, Mercury free, arsenic-free glass, Dell ComfortView
- Black
- 53.2 cm x 18 cm x 35.71 cm - with stand
- 5.16 kg
- HDMI , DisplayPort , VGA , USB 3.0 upstream , 2 x USB 2.0 downstream , 2 x USB 3.0 downstream
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), integrated cable management, anti-theft protection, Dell Soundbar mounting slots
- Cables Included
- 1 x VGA cable ¦ 1 x DisplayPort cable ¦ 1 x SuperSpeed USB cable
- EMC, DDC/CI, RoHS
- Security Slot Type
- Kensington security slot
- Input Voltage
- 15 W
- Power Consumption (Typical)
- 18 watt
- Power Consumption Stand by
- 0.3 watt
- Power Consumption Sleep
- 0.3 watt
- 0.3 watt
- Included Software
- Dell Display Manager
- Dimensions & Weight Details
- With stand - width: 53.2 cm - depth: 18 cm - height: 35.71 cm - weight: 5.16 kg , Without stand - width: 53.2 cm - depth: 5.03 cm - height: 31.59 cm - weight: 3.06 kg
- Shipping Weight
- 7.34 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Carbon Footprint
- Total CF/unit Standard Deviation (kg CO2e)
- 92
- Manufacturing (kg CO2e)
- 330
- Logistics (kg CO2e)
- 47
- Use (kg CO2e)
- 113
- EOL (kg CO2e)
- 3
- Total Carbon w/o Use Phase (kg CO2e)
- 379
- PAIA Version
- 9/5/2018
- Limited warranty - 3 years
- Bundled Services
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount | In Stock | £139.14 |
StarTech.com Dual Monitor Stand | In Stock | £82.12 |
StarTech.com TV/Monitor Arm - Wallmount | In Stock | £84.28 |
StarTech.com Monitor Arm - Heavy Duty | In Stock | £95.48 |
