StarTech.com M.2 SATA external SSD enclosure USB 3.0 with UASP
Quicklinx: B459WS00 Mfr#: SM2NGFFMBU33
Type: Storage enclosure
HD Size: M.2
Power Supply: [N/A]
More than 50 In Stock
£19.70 ex VAT
£23.64 inc VAT
Turn your solid state drive into an ultra-portable pocket drive. The SM2NGFFMBU33 external USB 3.0 to M.2 (NGFF) enclosure turns your SATA M.2 solid state drive into a portable, high speed USB 3.0 drive.
Get higher external performance by using an M.2 SSD in place of a platter drive, harnessing the full potential of your USB 3.0 computer system. The enclosure supports UASP, enabling you to achieve transfer speeds up to 70% faster than traditional USB 3.0 when used with a UASP-enabled host computer.
This slim, pocket-sized SSD enclosure has been specifically engineered for mobility. The enclosure features a lightweight yet durable design, which fits easily into your pocket or laptop bag. For further convenience, the enclosure is powered entirely using the USB host bus and requires no external power adapter.
Durable aluminum construction helps to ensure your drive won't be damaged while you're on the move. Plus, to maximize heat dissipation the enclosure features specially engineered ventilation holes which help maintain a cooler operating environment for optimal performance and a longer life span for your drive.
For wide compatibility with all of the common M.2 solid state drives, the enclosure can mount multiple drive heights including: 2242, 2260, and 2280.
UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing UASP also shows an 80% reduction in required processor resources.
Testing results were obtained using an Intel Ivy Bridge system, a UASP enabled StarTech.com Enclosure, and a SATA III solid state drive.
  • Sturdy construction
    This storage enclosure features aluminum material, ensuring durability while providing effective thermal management.
  • High-speed data transfer
    The enclosure supports a data transfer rate of 6 Gbit/s over USB 3.0, enabling quick and efficient file transfers.
  • Broad compatibility
    Designed to support M.2 NGFF SATA drives, including B Key and B+M Key types, ensuring compatibility with various solid-state drives.
  • Portable design
    Its compact design allows for easy transport, making it perfect for on-the-go storage solutions.
  • Environmentally compliant
    This storage enclosure meets FCC and RoHS standards, reflecting a commitment to environmental responsibility.
StarTech.com M.2 SSD Aluminum Enclosure to USB 3.0 (5Gbps) with UASP - M.2 NGFF SATA with B Key & B+M Key - External M.2 Portable Enclosure (SM2NGFFMBU33) - storage enclosure - SATA 6Gb/s - USB 3.0
Storage enclosure - external
Bus Type
USB 3.0
Expansion Bays
1 x internal - M.2
Hard Drive Form Factor Compatibility
M.2
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Solid state drive
Max Storage Devices Qty
1
Product Material
Aluminium
3.5 cm x 10 cm x 1.5 cm
68 g
M.2
Host Bus
USB 3.0
Product Material
Aluminium
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Solid state drive
1
ASMedia ASM1153
Bays
1 x internal - M.2
1 x SATA 3Gb/s - SATA combo
1 x USB 3.0 - 9 pin USB Type B
Screwdriver, screws
1 x USB cable - external
USB powered
FCC, RoHS
3.5 cm
10 cm
1.5 cm
68 g
50 °C
B459 StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External In Stock £27.08
B459 StarTech.com 0.5m (1.5ft) Black SuperSpeed USB 3.0 Cable A to Micro B - M/M In Stock £7.36
B459 StarTech.com 2m (6ft) Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £11.19
B459 StarTech.com 0.5m (20in) Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £7.91
B459 StarTech.com 15cm (6in) Short Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £6.29
B459 StarTech.com 10ft Slim Micro USB 3.0 Cable In Stock £13.00
B459 StarTech.com M.2 SATA external SSD enclosure USB 3.0 with UASP In Stock £19.70
B459 StarTech.com 2x M.2 SSD Controller - PCIe In Stock £44.82
B459 StarTech.com M.2 SATA Enclosure with USB-C In Stock £25.64
B459 StarTech.com x4 PCI Express to M.2 PCIe SSD Adapter In Stock £18.59
B459 StarTech.com 3PT M.2 SSD Card - PCIe 3.0 In Stock £28.29
B459 StarTech.com U.2 2.5" NVMe SSD Adapter In Stock £21.67
B459 StarTech.com M.2 SATA Raspberry Pi Adapter In Stock £19.02
B459 StarTech.com Dual M.2 Enclosure - RAID In Stock £41.89
B459 StarTech.com U.2 to PCIe Adapter -SFF-8639 In Stock £31.05
B459 StarTech.com M.2 NVMe SSD Enclosure for PCIe SSDs - USB 3.1 Gen 2 Type-C In Stock £44.81
B459 StarTech.com x8 Dual M.2 PCI Express SSD Adapter - PCIe 3.0 for PCIe NVMe In Stock £129.01
B459 StarTech.com M.2 SSD Enclosure for M.2 SATA Drives - USB 3.1 - USB C M.2 In Stock £29.06
B459 StarTech.com M.2 NVMe PCIe SSD Enclosure - IP67 water/dust resistance In Stock £63.05
B459 StarTech.com USB-C 10Gbps to M.2 NVMe or M.2 SATA SSD Enclosure In Stock £46.39
B459 StarTech.com USB PCIE/SATA M.2 Enclosure In Stock £43.99
HD Size: M.2
Power Supply: [N/A]
