Upgrade your system speed and performance with this Dual M.2 PCIe SSD Adapter. It lets you add two high performance, enterprise-class PCIe 3.0 M.2 SSDs (NVMe and AHCI) into the PCIe 8-lane or larger slot of your desktop workstation or server.
The expansion card lets you take full advantage of the fast performance and compact size of PCIe M.2 internal solid-state drives. With the M.2 PCIe based drives in place, the adapter increases your storage capacity and gives your computer a significant speed boost, enhancing data transfer rates.
The dual M.2 to PCIe expansion card employs a high-speed ASM2824 switch, allowing you to access two drives at the same time. Since the adapter card does not rely on PCIe bifurcation, it can easily be integrated into all systems, new and legacy.
The M.2 PCI express adapter also gives you the flexibility to access your M.2 PCIe SSDs individually. Or, you can utilize software RAID to build a RAID array to add redundancy or enhance system performance.
The adapter? connects directly to your computer motherboard to support two PCIe M.2 SSDs through a x8 PCIe expansion slot. The adapter is compatible with PCIe 3.0 motherboards and is backward compatible with PCIe 2.0 and PCIe 1.0.
The PCIe M.2 NGFF (M Key) adapter supports PCIe 3.0 NVMe and PCIe-AHCI M.2 SSDs including 2242, 2260, and 2280 drives, supporting the most common drive sizes: 42, 60, and 80 mm lengths.
The expansion card comes with a full-profile bracket pre-installed, and includes a half-height / low-profile bracket, for installation in small form-factor computers.
Vented brackets on the PCIe M.2 NGFF SSD adapter card increases air flow to assist in heat dissipation.
Versatile storage expansion
This adapter supports M.2 NGFF solid-state drives in various sizes, allowing for flexible storage configurations to meet different needs. -
Effective heat management
Designed with ventilation holes, this adapter promotes airflow, helping to maintain operating temperatures for reliable performance. -
Robust compliance standards
The product meets several compliance standards including FCC, RoHS, WEEE, and RCM, ensuring safety and environmental responsibility. -
Long lifespan
With an MTBF of 3,336,103 hours, this adapter is built for durability, providing long-term reliability for your storage needs.
- StarTech.com Dual M.2 PCIe SSD Adapter Card, x8 / x16 Dual NVMe or AHCI M.2 SSD to PCI Express 3.0, M.2 NGFF PCIe (M-Key) Compatible, Vented, Supports 2242, 2260, 2280, JBOD, Mac & PC - Full/Low-Profile Brackets (PEX8M2E2) - interface adapter - M.2 Card - PCIe 3.0 x8 - TAA Compliant
- Interface adapter - plug-in card - low profile
- Bus Type
- PCIe 3.0 x8
- Red
- Supported Form Factor
- Expansion Slot to M.2
- Expansion Bays
- 2 x internal - M.2 NGFF 2242/2260/2280
- Hard Drive Form Factor Compatibility
- M.2
- Interface
- M.2 Card
- Supported Devices
- Solid state drive
- Max Storage Devices Qty
- 2
- TAA Compliant
- 2.2 cm x 17.4 cm x 12.2 cm
- 88 g
- 2-year warranty
- M.2
- Host Bus
- PCIe 3.0 x8
- Red
Storage Controller
- Interface
- M.2 Card
- Supported Devices
- Solid state drive
- 2
- Processor
- ASMedia ASM2824
- Bays
- 2 x - 2 pin IDC
- Included Accessories
- Low-profile bracket, full-height bracket, half-height bracket
- Supports AHCI mode, ventilation holes
- MTBF
- 3336103 hours
- FCC, RoHS, WEEE, RCM
Environmental Standards
- TAA Compliant
- Limited warranty - 2 years
- 2.2 cm
- 17.4 cm
- 12.2 cm
- 88 g
- Shipping Width
- 21.5 cm
- Shipping Depth
- 15.5 cm
- Shipping Height
- 4.5 cm
- Shipping Weight
- 195 g
- 5 °C
- 70 °C
- 15 - 90%
