Connect a USB 3.0 Micro USB external hard drive to your computer. The USB3AUB50CMB SuperSpeed USB 3.0 Micro B cable provides a high quality connection to your Micro USB-equipped USB 3.0 devices.
The short 0.5m /1.5-foot cable length is perfect for close-range connections (e.g. connecting a portable hard drive to your laptop) and the lightweight, compact design fits nicely into any carrying case.
Reliable connectivity
This USB cable is compliant with USB 3.0 standards, ensuring compatibility and efficient data exchange between devices. -
High-speed data transfer
With a data rate of up to 5 Gbps, this cable allows for quick and seamless file transfers, saving time during data management. -
Durable construction
The molded connectors provide added strength, reducing wear and tear from frequent use. -
Flexible compatibility
Featuring a 10 pin Micro-USB Type-B connector and a 9-pin USB Type-A connector, this cable connects a wide range of devices.
- StarTech.com 0.5m (1.5ft) Black SuperSpeed USB 3.0 Cable A to Micro B - USB 3.0 Micro B Cable - 1x USB 3 A (M), 1x USB 3 Micro B (M) 50cm (USB3AUB50CMB) - USB cable - Micro-USB Type B to USB Type A - 50 cm
- USB cable
- Technology
- Shielded
- Molded, 5 Gbps data rate
- Length
- 50 cm
- Connector
- 10 pin Micro-USB Type B - male
- Connector (Second End)
- 9 pin USB Type A - male
- USB 3.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: DKT30CVAGPD, S2510BPU337, S2510BU33PW, S251BMU313, S251BMU3FP, S251BPU313, S251BRU33, S251SMU33EP, S252BU313R, SLSODDU33B, SM2NGFFMBU33, SMS1BMU313, UNI251BMU33
- USB cable
- Technology
- Shielded
- American Wire Gauge (AWG)
- 28
- Length
- 50 cm
- Black
- Connector
- USB 3.0, RoHS
- Designed For
