Turn your solid state drive into an ultra-portable pocket drive. The SM2NGFFMBU33 external USB 3.0 to M.2 (NGFF) enclosure turns your SATA M.2 solid state drive into a portable, high speed USB 3.0 drive.
Get higher external performance by using an M.2 SSD in place of a platter drive, harnessing the full potential of your USB 3.0 computer system. The enclosure supports UASP, enabling you to achieve transfer speeds up to 70% faster than traditional USB 3.0 when used with a UASP-enabled host computer.
This slim, pocket-sized SSD enclosure has been specifically engineered for mobility. The enclosure features a lightweight yet durable design, which fits easily into your pocket or laptop bag. For further convenience, the enclosure is powered entirely using the USB host bus and requires no external power adapter.
Durable aluminum construction helps to ensure your drive won't be damaged while you're on the move. Plus, to maximize heat dissipation the enclosure features specially engineered ventilation holes which help maintain a cooler operating environment for optimal performance and a longer life span for your drive.
For wide compatibility with all of the common M.2 solid state drives, the enclosure can mount multiple drive heights including: 2242, 2260, and 2280.
UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing UASP also shows an 80% reduction in required processor resources.
Testing results were obtained using an Intel Ivy Bridge system, a UASP enabled StarTech.com Enclosure, and a SATA III solid state drive.
Sturdy construction
This storage enclosure features aluminum material, ensuring durability while providing effective thermal management. -
High-speed data transfer
The enclosure supports a data transfer rate of 6 Gbit/s over USB 3.0, enabling quick and efficient file transfers. -
Broad compatibility
Designed to support M.2 NGFF SATA drives, including B Key and B+M Key types, ensuring compatibility with various solid-state drives. -
Portable design
Its compact design allows for easy transport, making it perfect for on-the-go storage solutions. -
Environmentally compliant
This storage enclosure meets FCC and RoHS standards, reflecting a commitment to environmental responsibility.
- StarTech.com M.2 SSD Aluminum Enclosure to USB 3.0 (5Gbps) with UASP - M.2 NGFF SATA with B Key & B+M Key - External M.2 Portable Enclosure (SM2NGFFMBU33) - storage enclosure - SATA 6Gb/s - USB 3.0
- Storage enclosure - external
- Bus Type
- USB 3.0
- Black
- Expansion Bays
- 1 x internal - M.2
- Hard Drive Form Factor Compatibility
- M.2
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 6 Gbit/s
- Supported Devices
- Solid state drive
- Max Storage Devices Qty
- 1
- Product Material
- Aluminium
- 3.5 cm x 10 cm x 1.5 cm
- 68 g
- 2-year warranty
- M.2
- Host Bus
- USB 3.0
- Product Material
- Aluminium
- Black
Storage Controller
- Interface
- SATA 6Gb/s
- 6 Gbit/s
- Supported Devices
- Solid state drive
- 1
- Processor
- ASMedia ASM1153
- Bays
- 1 x SATA 3Gb/s - SATA combo
- Connections
- 1 x USB 3.0 - 9 pin USB Type B
- Included Accessories
- Screwdriver, screws
- Cables Included
- 1 x USB cable - external
- USB powered
- FCC, RoHS
- Limited warranty - 2 years
- 3.5 cm
- 10 cm
- 1.5 cm
- 68 g
- 0 °C
- 50 °C
StarTech.com 0.5m (1.5ft) Black SuperSpeed USB 3.0 Cable A to Micro B - M/M | In Stock | £8.16 |
StarTech.com 2m (6ft) Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M | In Stock | £11.00 |
StarTech.com 0.5m (20in) Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M | In Stock | £8.06 |
StarTech.com 15cm (6in) Short Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M | In Stock | £6.62 |
StarTech.com 10ft Slim Micro USB 3.0 Cable | In Stock | £12.79 |
StarTech.com M.2 SATA external SSD enclosure USB 3.0 with UASP | In Stock | £19.88 |
StarTech.com 2x M.2 SSD Controller - PCIe | In Stock | £21.26 |
StarTech.com M.2 SATA Enclosure with USB-C | In Stock | £25.86 |
StarTech.com x4 PCI Express to M.2 PCIe SSD Adapter | In Stock | £18.76 |
StarTech.com 3PT M.2 SSD Card - PCIe 3.0 | In Stock | £28.55 |
StarTech.com Dual M.2 Enclosure - RAID | In Stock | £42.94 |
StarTech.com U.2 to PCIe Adapter -SFF-8639 | In Stock | £27.51 |
StarTech.com M.2 NVMe SSD Enclosure for PCIe SSDs - USB 3.1 Gen 2 Type-C | In Stock | £40.35 |
StarTech.com x8 Dual M.2 PCI Express SSD Adapter - PCIe 3.0 for PCIe NVMe | In Stock | £135.47 |
StarTech.com M.2 SSD Enclosure for M.2 SATA Drives - USB 3.1 - USB C M.2 | In Stock | £29.33 |
StarTech.com M.2 NVMe PCIe SSD Enclosure - IP67 water/dust resistance | In Stock | £64.63 |
StarTech.com USB-C 10Gbps to M.2 NVMe or M.2 SATA SSD Enclosure | In Stock | £47.55 |
StarTech.com USB PCIE/SATA M.2 Enclosure | In Stock | £45.80 |
