StarTech.com IP67 Certified 2T2R 5GHz Outdoor Wireless-N Access Point - 300 Mbps WiFi AP
Quicklinx: 9YY7WS00 Mfr#: R300WN22MO5G
  • IEEE 802.11n
Add 5 GHz Wi-Fi coverage to an outdoor area, with a ruggedized industrial access point - PoE Powered. The R300WN22MO5G Outdoor Wireless Access Point lets you add 5 GHz Wireless-N network coverage to an outdoor area, through a ruggedized industrial access point.
This outdoor access point features an IP67 certified, die-cast metal enclosure with heavy-duty cable grommets so it can withstand the outdoor elements and offers pole and wall-mounting options. Plus, the PoE-powered AP includes a passive Power-over-Ethernet injector, enabling you to install it in locations where a typical power outlet is unavailable. PoE pass-through via the secondary LAN port lets you connect data and power to a PoE-capable device near the access point.
By isolating your Wi-Fi network to the 5 GHz frequency, dual-band smartphones, tablets or laptops can operate with less interference from other devices than on the more common 2.4 GHz band. For optimal wireless coverage, the AP broadcasts a signal through a high-powered 800 mW internal 10 dBi 2T2R antenna.
The device offers support for several different operating modes, which help you to create a wireless network from a wired connection, bridge multiple APs together or extend the range of an existing wireless network. The AP supports Wireless-N data rates up to 300 Mbps with security through WEP, WPA, or WPA2 authentication, all configurable through an easy-to-use web-based utility.
StarTech.com IP67 Certified 5GHz Outdoor Wireless-N Access Point - WiFi AP - radio access point - Wi-Fi
Radio access point
External - outdoor
United Kingdom
Atheros AR9342
IEEE 802.11a, IEEE 802.11n
Frequency Band
5 GHz
PoE injector
Power Over Ethernet (PoE) Supported
PoE
9.6 cm x 15.8 cm x 4.9 cm
820 g
Radio access point
Ruggedized Design
Outdoor
9.6 cm
15.8 cm
4.9 cm
820 g
Enclosure Colour
Grey
United Kingdom
Processor / Memory / Storage
Processors Installed
Atheros AR9342
External
Wireless
Data Transfer Rate
300 Mbps
Line Coding Format
64 QAM, BPSK, QPSK, 16 QAM, OFDM
Network / Transport Protocol
CSMA/CA
Frequency Band
5 GHz
Max Range Open Space
3.7 km
Status Indicators
Power, link/activity
2T2R MIMO technology
Encryption Algorithm
TKIP, WPA, WEP
IEEE 802.3, IEEE 802.3u, IEEE 802.11a, IEEE 802.11n
Aerial
Antenna
Internal
Antenna Qty
1
Gain Level
10 dBi
2 x - RJ-45
PoE injector
RoHS, IP67
PoE
External power adapter
-30 °C
60 °C
0 - 100% (non-condensing)
9YY7 StarTech.com Cat 6 RJ45 Stranded Modular Plug Connector - 50 Pack In Stock £20.64
