Convert an HDMI video signal to VGA, with discrete audio output. The HD2VGAA2 HDMI to VGA Adapter Cable enables you to connect an HDMI output device, such as a laptop video output or digital media extender to a VGA display device (monitor, projector) by converting the HDMI video signal from the output device into a VGA output and separate 2-channel analog audio. The HDMI to VGA adapter is intended for displaying user generated content such as presentations, documents, and work sheets onto a VGA projector or monitor. The adapter can also extend your computer's desktop to double your workspace and increase productivity.
The versatile converter supports resolutions including high definition 1080p, up to 1920x1200, which eliminates the expense of upgrading a VGA display for the sake of compatibility, and doesn't require a separate power adapter which saves installation time and hassle.
Versatile Connectivity
This adapter features a 19-pin HDMI Type-A male connector as input and several output options including a 15 pin HD D-Sub (HD-15), mini-phone 3.5 mm audio jack, and a 5 pin Micro-USB Type-B, ensuring compatibility with various devices. -
High-Quality Audio and Video
With support for 1080p resolution and multi-channel audio, this adapter delivers clear visuals and sound, suitable for a variety of applications from work presentations to enjoying media. -
Active Adapter Technology
Featuring active adapter technology, it ensures stable and consistent video signal conversion from HDMI to VGA, providing better performance over passive adapters. -
Sturdy Design
The durable plastic jacket of this adapter enhances longevity while protecting internal components, making it dependable for regular use in different environments. -
Compliance and Safety
The adapter meets FCC, RoHS, WEEE, REACH, and RCM standards, ensuring it adheres to environmental regulations and safety protocols.
- StarTech.com HDMI to VGA Video Adapter Converter with Audio for Desktop PC / Laptop / Ultrabook - 1920x1080 - adapter - HDMI / VGA / audio - 25 cm
- Cable
- Adapter - HDMI / VGA / audio
- Max Output Resolution
- 1920 x 1080 - 60 Hz
- Length
- 25 cm
- Black
- Connectors
- HDMI - male (input)
- Connectors (Second End)
- HD-15 (VGA) - female (output) , Mini jack - female (output) , Micro-USB Type B - female
- 1080p support, active adapter
- 3-year warranty
- Designed For
- P/N: DK30CH2DEP, DK30CH2DEPUE, MST30C2DPPD
- Cable Type
- Adapter 1080p support, active
- Interface Supported
- Jacket Material
- Plastic
- Length
- 25 cm
- Multi-channel audio
- Black
Adapters & Converters
- 1920 x 1080
- Refresh Rate
- 60 Hz
- Connectors
- 19 pin HDMI Type A - male (input)
- 15 pin HD D-Sub (HD-15) - female (output) , Mini-phone 3.5 mm - female (output) , 5 pin Micro-USB Type B - female
- FCC, RoHS, WEEE, REACH, RCM
- 4.5 cm
- 1.5 cm
- 36 g
- Shipping Width
- 8 cm
- Shipping Depth
- 18 cm
- Shipping Height
- 2 cm
- Shipping Weight
- 66 g
- Limited warranty - 3 years
- Designed For
StarTech.com 1 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £4.56 |
StarTech.com HDMI to VGA Video Adapter Converter with Audio - HD to VGA Monitor 1080p | In Stock | £13.96 |
StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.00 |
StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.63 |
StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.06 |
StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.78 |
StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male | In Stock | £4.91 |
StarTech.com HDMI to VGA Adapter Converter for Desktop PC / Laptop / Ultrabook - 1920x1080 | In Stock | £22.81 |
StarTech.com Micro HDMI to VGA Adapter Converter for Smartphones / Ultrabook / Tablet - 1920x1080 | In Stock | £22.95 |
StarTech.com HDMI to VGA Video Adapter Converter with Audio for Desktop PC / Laptop / Ultrabook | In Stock | £16.15 |
StarTech.com Compact HDMI to VGA Adapter Converter - Ideal for Chromebooks Ultrabooks & Laptops | In Stock | £14.78 |
StarTech.com 10ft HDMI to VGA adapter cable | In Stock | £34.95 |
StarTech.com 3ft HDMI to VGA adapter cable | In Stock | £17.68 |
StarTech.com 6ft HDMI to VGA adapter cable | In Stock | £20.08 |
StarTech.com HDMI to VGA Adapter w/ Audio | In Stock | £12.56 |
