StarTech.com 3ft HDMI to VGA adapter cable
PRICE DROP!
Last Few Remaining
Price Drop
Quicklinx: B144WS00 Mfr#: HD2VGAMM3
30 In Stock
£17.83 ex VAT
£21.39 inc VAT
Eliminate excess cable clutter and adapters, by connecting your HDMI source directly to a VGA monitor/projector using this short 3ft adapter cable. The HD2VGAMM3 3ft HDMI to VGA converter cable lets you connect your HDMI equipped Chromebook, laptop or desktop to a VGA monitor or projector, with no additional adapters or cables required.
The converter cable saves you the hassle of combining an HDMI to VGA adapter with a bulky VGA cable by providing an end-to-end solution for connecting your digital HDMI computer to your VGA monitor or projector.
Unlike most HDMI to VGA adapters which require a power outlet to convert the video signal, the HD2VGAMM3 doesn't need external power in most installations. To work with Mac computers where extra power is needed, the HD2VGAMM3 features an optional integrated USB power source (USB cable not included), which makes connecting a display to your desktop or workstation that much easier, if additional power is required.
In the past, converting digital HDMI to analog VGA was a difficult and expensive task. Now, you can avoid upgrade costs by connecting your HDMI video source to your existing VGA monitor or projector using the HD2VGAMM3. Plus, because the adapter cable supports video resolutions up to 1920x1200 or 1080p, you can rest assured you can use your existing VGA display while maintaining high-definition video quality.
The HD2VGAMM3 converter cable delivers a precise 3ft connection that eliminates the clutter of excess cable length and ensures a tidy, professional installation. For longer installations, StarTech.com also offers a 6 ft HDMI to VGA cable(HD2VGAMM6) and a 10 ft HDMI to VGA cable(HD2VGAMM10), enabling you to choose the right cable length for your installation needs.
Digitally encrypted content from the HDMI video source will not be displayed.
StarTech.com HDMI to VGA Cable - 3 ft / 1m - 1080p - 1920 x 1200 - Active HDMI Cable - Monitor Cable - Computer Cable (HD2VGAMM3) - adapter cable - HDMI / VGA - 1 m
Cable
Adapter cable - HDMI / VGA
Max Output Resolution
1920 x 1200
Length
1 m
Connectors
HDMI - male , Micro-USB Type B (power only) - female
Connectors (Second End)
HD-15 (VGA) - male
Active cable, 1920 x 1200 (WUXGA) support
3-year warranty
Cable Type
Adapter cable active, 1920 x 1200 (WUXGA) support
Interface Supported
HDMI / VGA
Length
1 m
USB powered
Adapters & Converters
1920 x 1200
Connectors
19 pin HDMI Type A - male , 5 pin Micro-USB Type B (power only) - female
FCC, RoHS
68.7 g
Shipping Width
19.6 cm
Shipping Depth
21.8 cm
Shipping Height
1 cm
Shipping Weight
88 g
Limited warranty - 3 years
B144 StarTech.com HDMI to VGA Adapter Converter for Desktop PC / Laptop / Ultrabook - 1920x1080 In Stock £26.54
B144 StarTech.com Micro HDMI to VGA Adapter Converter for Smartphones / Ultrabook / Tablet - 1920x1080 In Stock £27.45
B144 StarTech.com HDMI to VGA Video Adapter Converter with Audio for Desktop PC / Laptop / Ultrabook In Stock £16.31
B144 StarTech.com Compact HDMI to VGA Adapter Converter - Ideal for Chromebooks Ultrabooks & Laptops In Stock £14.96
B144 StarTech.com 10ft HDMI to VGA adapter cable In Stock £41.12
B144 StarTech.com 3ft HDMI to VGA adapter cable In Stock £17.83
B144 StarTech.com 6ft HDMI to VGA adapter cable In Stock £20.35
