StarTech.com HDMI to VGA Video Adapter Converter with Audio for Desktop PC / Laptop / Ultrabook
Quicklinx: 8Y6LWS00 Mfr#: HD2VGAA2
More than 50 In Stock
£16.15 ex VAT
£19.38 inc VAT
Convert an HDMI video signal to VGA, with discrete audio output. The HD2VGAA2 HDMI to VGA Adapter Cable enables you to connect an HDMI output device, such as a laptop video output or digital media extender to a VGA display device (monitor, projector) by converting the HDMI video signal from the output device into a VGA output and separate 2-channel analog audio. The HDMI to VGA adapter is intended for displaying user generated content such as presentations, documents, and work sheets onto a VGA projector or monitor. The adapter can also extend your computer's desktop to double your workspace and increase productivity.
The versatile converter supports resolutions including high definition 1080p, up to 1920x1200, which eliminates the expense of upgrading a VGA display for the sake of compatibility, and doesn't require a separate power adapter which saves installation time and hassle.
  • Versatile Connectivity
    This adapter features a 19-pin HDMI Type-A male connector as input and several output options including a 15 pin HD D-Sub (HD-15), mini-phone 3.5 mm audio jack, and a 5 pin Micro-USB Type-B, ensuring compatibility with various devices.
  • High-Quality Audio and Video
    With support for 1080p resolution and multi-channel audio, this adapter delivers clear visuals and sound, suitable for a variety of applications from work presentations to enjoying media.
  • Active Adapter Technology
    Featuring active adapter technology, it ensures stable and consistent video signal conversion from HDMI to VGA, providing better performance over passive adapters.
  • Sturdy Design
    The durable plastic jacket of this adapter enhances longevity while protecting internal components, making it dependable for regular use in different environments.
  • Compliance and Safety
    The adapter meets FCC, RoHS, WEEE, REACH, and RCM standards, ensuring it adheres to environmental regulations and safety protocols.
StarTech.com HDMI to VGA Video Adapter Converter with Audio for Desktop PC / Laptop / Ultrabook - 1920x1080 - adapter - HDMI / VGA / audio - 25 cm
Cable
Adapter - HDMI / VGA / audio
Max Output Resolution
1920 x 1080 - 60 Hz
Length
25 cm
Connectors
HDMI - male (input)
Connectors (Second End)
HD-15 (VGA) - female (output) , Mini jack - female (output) , Micro-USB Type B - female
1080p support, active adapter
3-year warranty
P/N: DK30CH2DEP, DK30CH2DEPUE, MST30C2DPPD
Cable Type
Adapter 1080p support, active
Interface Supported
HDMI / VGA / audio
Jacket Material
Plastic
Length
25 cm
Multi-channel audio
Adapters & Converters
1920 x 1080
Refresh Rate
60 Hz
Connectors
19 pin HDMI Type A - male (input)
15 pin HD D-Sub (HD-15) - female (output) , Mini-phone 3.5 mm - female (output) , 5 pin Micro-USB Type B - female
FCC, RoHS, WEEE, REACH, RCM
4.5 cm
1.5 cm
36 g
Shipping Width
8 cm
Shipping Depth
18 cm
Shipping Height
2 cm
Shipping Weight
66 g
Limited warranty - 3 years
8Y6L StarTech.com 1 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £4.56
8Y6L StarTech.com HDMI to VGA Video Adapter Converter with Audio - HD to VGA Monitor 1080p In Stock £13.92
8Y6L StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.00
8Y6L StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.63
8Y6L StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.06
8Y6L StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.78
8Y6L StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male In Stock £4.91
8Y6L StarTech.com HDMI to VGA Adapter Converter for Desktop PC / Laptop / Ultrabook - 1920x1080 In Stock £22.81
8Y6L StarTech.com Micro HDMI to VGA Adapter Converter for Smartphones / Ultrabook / Tablet - 1920x1080 In Stock £22.95
8Y6L StarTech.com HDMI to VGA Video Adapter Converter with Audio for Desktop PC / Laptop / Ultrabook In Stock £16.15
8Y6L StarTech.com Compact HDMI to VGA Adapter Converter - Ideal for Chromebooks Ultrabooks & Laptops In Stock £14.78
8Y6L StarTech.com 10ft HDMI to VGA adapter cable In Stock £34.95
8Y6L StarTech.com 3ft HDMI to VGA adapter cable In Stock £17.68
8Y6L StarTech.com 6ft HDMI to VGA adapter cable In Stock £20.08
8Y6L StarTech.com HDMI to VGA Adapter w/ Audio In Stock £12.56
Type: Signal Converter
