1 In 2 Out Video Splitter , HDMI 2.0 , HDR , 2-Year Warranty. This 2-Port 4K HDMI splitter connects your HDMI video source to two HDMI displays at the same time, without distorting or degrading your video signal. For dependable performance, the splitter features a durable metal housing that provides passive cooling.
With transmission bandwidth up to 18Gbps, this HDMI splitter is fully compatible with your HDMI 2.0 equipment, supporting UHD resolutions up to 4096x2160 (4K) at 60Hz. For smooth video and color transitions, the splitter offers 4:4:4 chroma subsampling, so every pixel gets its own unique color.
The splitter also supports High Dynamic Range (HDR) imaging, offering a greater luminosity than standard digital imaging.
The 2-way HDMI splitter supports HDCP 2.2 and is backward compatible with 4K 30Hz and 1080p displays. This ensures that it will work with almost any HDMI source, or destination device such as computers, Blu-ray players, monitors, TVs and projectors. Perfect for digital signage applications, where equipment may vary throughout your site.
For hassle-free setup, the 1x2 HDMI splitter offers easy plug-and-play installation. The splitter also saves you setup time by automatically passing EDID between your video source and the display attached to port 1, ensuring settings like native resolution and refresh rate are configured properly.
True 4K at 60Hz and HDR
With transmission bandwidth up to 18Gbps, this HDMI splitter is fully compatible with your HDMI 2.0 equipment, supporting UHD resolutions up to 4096x2160 (4K) at 60Hz. For smooth video and color transitions, the splitter offers 4:4:4 chroma subsampling, so every pixel gets its own unique color. The splitter also supports High Dynamic Range (HDR) imaging, offering a greater luminosity than standard digital imaging. -
Widely Compatible
The 2-way HDMI splitter supports HDCP 2.2 and is backward compatible with 4K 30Hz and 1080p displays. This ensures that it will work with almost any HDMI source, or destination device such as computers, Blu-ray players, monitors, TVs and projectors. Perfect for digital signage applications, where equipment may vary throughout your site. -
Easy Installation
For hassle-free setup, the 1x2 HDMI splitter offers easy plug-and-play installation. The splitter also saves you setup time by automatically passing EDID between your video source and the display attached to port 1, ensuring settings like native resolution and refresh rate are configured properly. ST122HD202 is backed by a 2-year StarTech.com warranty and free lifetime technical support.
- StarTech.com HDMI Splitter - 2-Port - 4K 60Hz - HDMI Splitter 1 In 2 Out - 2 Way HDMI Splitter - HDMI Port Splitter (ST122HD202) - video/audio splitter - 2 ports
- Video/audio splitter - 2 ports
- Subtype
- HDMI
- Ports
- 2 x HDMI
- 7.1 channel audio support, Dolby TrueHD support, DTS-HD Master Audio support, HDR support
- HDCP 2.2
- Power
- AC 120/230 V
- 10 cm x 5.6 cm x 1.7 cm
- 159 g
- Black
- Localisation
- Australia, New Zealand, North America, United Kingdom, Europe
- 2-year warranty
- Designed For
- P/N: ST121HD20FXA
- Enclosure Type
- Desktop
- Subtype
- HDMI
- Ports
- 2 x HDMI
- Max Resolution
- 3840 x 2160 @ 60 Hz
- HDCP 2.2
- Status Indicators
- Power
- 1 x HDMI input , 2 x HDMI output
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- 5 Watt
- Black
- FCC, RoHS, WEEE
- Localisation
- 10 cm
- 5.6 cm
- 1.7 cm
- 159 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 20 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
- Designed For
- P/N: ST121HD20FXA
StarTech.com 4 Port High Speed HDMI Video Splitter w/ Audio | In Stock | £103.47 |
StarTech.com 2 Port High Speed HDMI Video Splitter and Signal Amplifier | In Stock | £84.19 |
StarTech.com 4K HDMI 2-Port Video Splitter – 1x2 HDMI Splitter – Powered by USB or Power Adapter | In Stock | £54.08 |
StarTech.com 4K HDMI 4-Port Video Splitter | In Stock | £62.29 |
StarTech.com 5m DisplayPort to HDMI Cable - 4K | In Stock | £22.69 |
StarTech.com 2m 6ft Premium HDMI 2.0 Cable | In Stock | £15.45 |
StarTech.com 3m 10ft Premium HDMI 2.0 Cable | In Stock | £20.38 |
StarTech.com 2m Premium HDMI Cable - Grips | In Stock | £14.25 |
StarTech.com 5m 15ft Premium 4K HDMI Cable | In Stock | £25.63 |
StarTech.com 7m 23ft Premium 4K HDMI Cable | In Stock | £38.28 |
StarTech.com 0.5m Premium 4K HDMI Cable | In Stock | £10.05 |
StarTech.com 10m CL2 Active HDMI Cable - 4K | In Stock | £78.49 |
StarTech.com 15m CL2 Active HDMI Cable - 4K | In Stock | £98.92 |
StarTech.com 8-Port 4K 60Hz HDMI Splitter | In Stock | £134.78 |
StarTech.com HDMI Splitter - 2 Port - 4K 60Hz | In Stock | £38.79 |
StarTech.com HDMI Splitter - 4 Port - 4K 60Hz | In Stock | £54.75 |
StarTech.com 2-Port HDMI Splitter, 4K 60Hz | In Stock | £56.29 |
