This 2-port HDMI splitter displays the same image from an HDMI video source onto two HDMI displays, with support for UHD 4K resolutions, HDR (High Dynamic Range), HDCP content, and 7.1 channel audio.
4K 60Hz Resolution
This 2-way HDMI splitter supports up to 4K 60Hz resolution and 4:4:4 chroma subsampling. Display 4K content on both your 4K displays or downscale the resolution to 1080p to support monitors with different resolutions, thanks to the built-in scaler. Ideal for environments containing displays of mixed resolutions. -
USB Powered
The splitter includes a 31inch (78cm) USB Micro-B to Type-A power cable and USB wall charger. If an outlet is not available or within reach, the USB power cable can be connected to a 5V 1A USB Type-A port. -
Robust Installation Options
This HDMI splitter supports active HDMI cables and HDMI extenders (sold separately), facilitating installations at a distance from the displays (e.g., within a remote AV component cabinet). The reset button enables hassle-free hot plug EDID detection, without the need of unplugging cables. The splitter features 8kV air and 6kV contact Electrostatic Discharge (ESD) protection, suitable for installation in a variety of environments. This product is backed for 2 years, including free lifetime 24/5 multi-lingual technical assistance.
- StarTech.com 2-Port HDMI Splitter, 4K 60Hz HDMI 2.0 Video, 4K HDMI Splitter 1 In 2 Out, 1x2 HDMI Display/Output Splitter, HDR/HDCP - 20in (50cm) Built-in HDMI Cable, Powered via USB or Included Power Supply (HDMI-SPLITTER-4K60UP) - video/audio splitter - 2 ports
- Video/audio splitter - 2 ports
- Subtype
- HDMI
- Performance
- Total bandwidth: 18 Gbps
- Reset button, 7.1 channel audio support, EDID Management, auto scaler, 8KV ESD Protector (air-gap discharge), HDR support, 6KV ESD Protector (contact discharge), 4K UHD video streaming, 4:4:4 chroma subsampling support
- HDCP 1.4, HDCP 2.2
- Power
- AC 100-240 V 0.3 A
- 5.5 cm x 6.5 cm x 1.9 cm
- 92 g
- Black
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- HDMI
- Performance
- Max Resolution
- 4K @ 60 Hz
- Status Indicators
- Port status, power
- 1 x HDMI input Type A male , 2 x HDMI output Type A female , 1 x micro-USB Type B
- Power Device
- External power adapter
- Power Provided
- DC 5 V - 1 A
- Voltage Required
- AC 100-240 V
- Electric Current Required
- 0.3 A
- 5 Watt
- Black
- Cables Included
- 1 x HDMI cable - 50.8 cm , 1 x USB-A to Micro-USB Type B cable - 78 cm
- RoHS, WEEE
- 5.5 cm
- 6.5 cm
- 1.9 cm
- 92 g
- Shipping Width
- 19 cm
- Shipping Depth
- 14.5 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 168 g
- Limited warranty - 2 years , Technical support - assistance - lifetime
- 0 °C
- 70 °C
- 5 - 90% RH (non-condensing)
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 80 °C
StarTech.com 3ft (1m) HDMI 2.1 Cable 8K - Certified Ultra High Speed HDMI | In Stock | £16.49 |
StarTech.com 6ft (2m) HDMI 2.1 Cable 8K - Certified Ultra High Speed HDMI | In Stock | £20.48 |
StarTech.com 10ft Ultra High Speed HDMI 2.1 | In Stock | £23.74 |
StarTech.com 16ft Ultra High Speed HDMI 2.1 | In Stock | £39.48 |
