Split an HDMI audio and video signal to four displays simultaneously. The ST124HDMI2 4 Port High Speed HDMI Video Splitter with Audio lets you share a single HDMI source with up to 4 HDMI or DVI-D enabled displays/receivers, without sacrificing image or sound quality. Mounting brackets are included for a tidy, professional installation.
Supporting true HD video resolutions up to 1080p, this HDMI splitter allows you to situate your HDMI-capable displays up to 15ft (5m) away from the splitter. This versatile HDMI splitter features 3.5mm audio input and output connections giving you the option of sending your accompanying audio signal through the HDMI cable or through a separate 3.5mm stereo audio channel.
A perfect addition to virtually any application requiring the high quality video delivered by HDMI devices, the ST124HDMI2 video splitter is easy to install and provides flawless, distortion-free digital video.
- StarTech.com HDMI Splitter 1 In 4 Out - 1080p - 4 Port -Mounting Brackets - 1.3 Audio - HDMI Multi Port - HDMI Audio Splitter (ST124HDMI2) - video splitter - 4 ports
- Video splitter - 4 ports
- Subtype
- HDMI
- Ports
- 4 x HDMI + 4 x audio
- Power
- AC 120/230 V
- 13.5 cm x 22 cm x 4.4 cm
- 1.6 kg
- Black
- 2-year warranty
- Designed For
- P/N: SVA12M2NEUA, SVA12M5NA
- Enclosure Type
- Desktop
- Subtype
- HDMI
- Ports
- Max Resolution
- 1920 x 1200 / 1080p
- HDTV support
- 4 x HDMI output , 4 x audio output mini-jack , 1 x HDMI input , 1 x audio input mini-jack
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Black
- 13.5 cm
- 22 cm
- 4.4 cm
- 1.6 kg
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 80%
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
- Designed For
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £7.80 |
StarTech.com 1U Rackmount Brackets for KVM Switch (SV431 Series) | In Stock | £22.32 |
StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.37 |
StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.56 |
StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.97 |
StarTech.com 12V DC 1.5A Universal Power Adapter | In Stock | £18.33 |
StarTech.com 2 Port High Speed HDMI Video Splitter and Signal Amplifier | In Stock | £69.74 |
StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male | In Stock | £4.94 |
StarTech.com 4K HDMI 2-Port Video Splitter – 1x2 HDMI Splitter – Powered by USB or Power Adapter | In Stock | £50.75 |
StarTech.com DC Power Adapter - 12V, 2A | In Stock | £11.76 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £42.05 |
StarTech.com 8-Port 4K 60Hz HDMI Splitter | In Stock | £133.22 |
StarTech.com HDMI Splitter - 2 Port - 4K 60Hz | In Stock | £40.20 |
StarTech.com HDMI Splitter - 4 Port - 4K 60Hz | In Stock | £55.73 |
