StarTech.com 8-Port 4K 60Hz HDMI Splitter
Quicklinx: DMN3WS00 Mfr#: ST128HD20
Type: Video/audio splitter
Connectivity: HDMI
Ports: 8
Hurry, only 3 left in stock!
£133.22 ex VAT
£159.86 inc VAT
This 4K HDMI splitter lets you connect your HDMI video source to eight HDMI displays, with support for Ultra HD resolutions and HDR (High Dynamic Range) as well as 7.1 surround sound audio.
This 8-port 4K 60Hz HDMI splitter offers full support for your HDMI 2.0 equipment, including true 4K resolution at 60Hz. For smoother video and color transitions, the splitter offers 4:4:4 chroma subsampling, meaning every pixel gets its own unique color. Support for HDMI 2.0 devices means this splitter can transmit bandwidth up to 18Gbps, making it the ideal solution for high-resolution tasks requiring the highest color detail.
The splitter supports HDCP 2.2 and is backward compatible with 4K 30Hz and 1080p displays. This ensures that it will work with lower resolution displays such as TVs or projectors around your site or in your digital signage application.
The 4K HDMI splitter offers easy plug-and-play installation with no additional software or drivers required. The splitter passes EDID between your video source and the display attached to port 1, ensuring native settings such as resolution and refresh rate are configured automatically.
  • Supports true 4K at 60Hz
    This 8-port 4K 60Hz HDMI splitter offers full support for your HDMI 2.0 equipment, including true 4K resolution at 60Hz. For smoother video and color transitions, the splitter offers 4:4:4 chroma subsampling, meaning every pixel gets its own unique color. Support for HDMI 2.0 devices means this splitter can transmit bandwidth up to 18Gbps, making it the ideal solution for high-resolution tasks requiring the highest color detail. Note: In order to support 4K 60Hz coming through the splitter, each device in the chain must support HDCP 2.2.
  • Widely compatible
  • Easy installation and setup
    The 4K HDMI splitter offers easy plug-and-play installation with no additional software or drivers required. The splitter passes EDID between your video source and the display attached to port 1, ensuring native settings such as resolution and refresh rate are configured automatically. The ST128HD20 is backed by a 2-year StarTech.com warranty.
StarTech.com 4K 60hz HDMI Splitter - 8 Port - HDR Support - 7.1 Surround Sound Audio - HDMI Distribution Amplifier - HDMI 2.0 Splitter (ST128HD20) - video/audio splitter
Subtype
HDMI
Ports
8 x HDMI
4K resolution support, 7.1 channel audio support
AC 120/230 V
25.8 cm x 11.35 cm x 2.6 cm
1.3 kg
P/N: ST121HD20FXA
Subtype
HDMI
Ports
8 x HDMI
Status Indicators
Power, input, output
1 x HDMI input , 8 x HD-SDI output
External power adapter
Power Provided
3 A
AC 120/230 V
15 Watt
Mounting brackets
HDCP 2.2
25.8 cm
11.35 cm
2.6 cm
1.3 kg
45 °C
10 - 85% (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
Humidity Range Storage
P/N: ST121HD20FXA
DMN3 StarTech.com 4 Port High Speed HDMI Video Splitter w/ Audio In Stock £91.53
DMN3 StarTech.com 2 Port High Speed HDMI Video Splitter and Signal Amplifier In Stock £69.74
DMN3 StarTech.com 4K HDMI 2-Port Video Splitter – 1x2 HDMI Splitter – Powered by USB or Power Adapter In Stock £49.62
DMN3 StarTech.com HDMI Splitter - 4 Port - 4K 60Hz In Stock £54.49
DMN3 StarTech.com 55-Bit Electric Precision Screwdriver Set In Stock £59.62
DMN3 StarTech.com 4-Port HDMI Splitter, 4K 60Hz In Stock £113.00
Connectivity: HDMI
Ports: 8
