4K 60Hz Resolution
This 4-way HDMI splitter supports up to 4K 60Hz resolution, at 4:4:4 chroma subsampling. The built-in scaler enables enables the concurrent output of 2 resolutions, ideal for environments where there is a variety of displays, monitors, and projectors. -
Flexible Audio
This 4K HDMI Splitter features HDMI, 3.5mm, and Optical audio outputs, enabling connections to a variety of speakers and/or amplifiers. Simultaneous audio output is supported across all the audio ports. -
Robust Installation Options
This HDMI splitter supports active HDMI cables and HDMI extenders (sold separately), facilitating installations at a distance from the displays (e.g., within a remote AV component cabinet). The metal enclosure and 8kV air and 4kV contact Electro-static Discharge (ESD) protection is suitable for installation in a variety of environments. This product is backed for 2-years, including free lifetime 24/5 multi-lingual technical assistance.
- StarTech.com 4-Port HDMI Splitter, 4K 60Hz HDMI 2.0 Video, 1 In 4 Out HDMI Splitter, 4K HDMI Splitter w/Built-in Scaler, 3.5mm/Optical Audio Port, Durable Metal Housing, HDR/HDCP - 1x4 HDMI Display/Output Splitter (HDMI-SPLITTER-44K60S) - video/audio splitter - 4 ports
- Video/audio splitter - 4 ports
- Subtype
- HDMI
- Ports
- 4 x HDMI
- 7.1 channel audio support, EDID Management, auto scaler, HDR support, 4K UHD video streaming, 4:4:4 chroma subsampling support, 18 Gbps bandwidth
- HDCP 1.4, HDCP 2.2
- Power
- AC 100-240 V 0.35 A
- 18 cm x 6.2 cm x 1.4 cm
- 244 g
- Black
- Localisation
- Australia, New Zealand, North America, United Kingdom, Europe
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- HDMI
- Ports
- 4 x HDMI
- Max Resolution
- 3840 x 2160 @ 60 Hz
- Status Indicators
- Power, HDMI input, HDMI output
- 1 x HDMI input Type A , 4 x HDMI output Type A , 1 x TOSLINK output , 1 x audio output mini-jack stereo audio
- Power Device
- External power adapter
- Power Provided
- DC 5 V - 1 A
- Voltage Required
- AC 100-240 V
- Electric Current Required
- 0.35 A
- 0.1 Watt
- Black
- FCC, RoHS, WEEE, FCC Part 15 Class B, CAN ICES-3(B)/NMB3(B), ESD
- Localisation
- 18 cm
- 6.2 cm
- 1.4 cm
- 244 g
- Shipping Width
- 21.2 cm
- Shipping Depth
- 14.8 cm
- Shipping Height
- 5.5 cm
- Shipping Weight
- 500 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 20 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
