This 4K HDMI splitter lets you connect your HDMI video source to eight HDMI displays, with support for Ultra HD resolutions and HDR (High Dynamic Range) as well as 7.1 surround sound audio.
This 8-port 4K 60Hz HDMI splitter offers full support for your HDMI 2.0 equipment, including true 4K resolution at 60Hz. For smoother video and color transitions, the splitter offers 4:4:4 chroma subsampling, meaning every pixel gets its own unique color. Support for HDMI 2.0 devices means this splitter can transmit bandwidth up to 18Gbps, making it the ideal solution for high-resolution tasks requiring the highest color detail.
The splitter supports HDCP 2.2 and is backward compatible with 4K 30Hz and 1080p displays. This ensures that it will work with lower resolution displays such as TVs or projectors around your site or in your digital signage application.
The 4K HDMI splitter offers easy plug-and-play installation with no additional software or drivers required. The splitter passes EDID between your video source and the display attached to port 1, ensuring native settings such as resolution and refresh rate are configured automatically.
Supports true 4K at 60Hz
This 8-port 4K 60Hz HDMI splitter offers full support for your HDMI 2.0 equipment, including true 4K resolution at 60Hz. For smoother video and color transitions, the splitter offers 4:4:4 chroma subsampling, meaning every pixel gets its own unique color. Support for HDMI 2.0 devices means this splitter can transmit bandwidth up to 18Gbps, making it the ideal solution for high-resolution tasks requiring the highest color detail. Note: In order to support 4K 60Hz coming through the splitter, each device in the chain must support HDCP 2.2. -
Widely compatible
The splitter supports HDCP 2.2 and is backward compatible with 4K 30Hz and 1080p displays. This ensures that it will work with lower resolution displays such as TVs or projectors around your site or in your digital signage application. -
Easy installation and setup
The 4K HDMI splitter offers easy plug-and-play installation with no additional software or drivers required. The splitter passes EDID between your video source and the display attached to port 1, ensuring native settings such as resolution and refresh rate are configured automatically. The ST128HD20 is backed by a 2-year StarTech.com warranty.
- StarTech.com 4K 60hz HDMI Splitter - 8 Port - HDR Support - 7.1 Surround Sound Audio - HDMI Distribution Amplifier - HDMI 2.0 Splitter (ST128HD20) - video/audio splitter
- Video/audio splitter
- Subtype
- HDMI
- Ports
- 8 x HDMI
- 4K resolution support, 7.1 channel audio support
- Power
- AC 120/230 V
- 25.8 cm x 11.35 cm x 2.6 cm
- 1.3 kg
- 2-year warranty
- Designed For
- P/N: ST121HD20FXA
- Subtype
- HDMI
- Ports
- 8 x HDMI
- Status Indicators
- Power, input, output
- 1 x HDMI input , 8 x HD-SDI output
- Power Device
- External power adapter
- Power Provided
- 3 A
- Voltage Required
- AC 120/230 V
- 15 Watt
- Included Accessories
- Mounting brackets
- HDCP 2.2
- 25.8 cm
- 11.35 cm
- 2.6 cm
- 1.3 kg
- Limited warranty - 2 years
- 0 °C
- 45 °C
- 10 - 85% (non-condensing)
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- Designed For
- P/N: ST121HD20FXA
StarTech.com 4 Port High Speed HDMI Video Splitter w/ Audio | In Stock | £91.53 |
StarTech.com 4K HDMI 2-Port Video Splitter – 1x2 HDMI Splitter – Powered by USB or Power Adapter | In Stock | £50.75 |
StarTech.com HDMI Splitter - 4 Port - 4K 60Hz | In Stock | £55.73 |
StarTech.com 55-Bit Electric Precision Screwdriver Set | In Stock | £59.62 |
StarTech.com 4-Port HDMI Splitter, 4K 60Hz | In Stock | £113.00 |
