StarTech.com HDMI Splitter - 2 Port - 4K 60Hz
Quicklinx: DXFVWS00 Mfr#: ST122HD202
32 In Stock
£39.58 ex VAT
£47.49 inc VAT
1 In 2 Out Video Splitter , HDMI 2.0 , HDR , 2-Year Warranty. This 2-Port 4K HDMI splitter connects your HDMI video source to two HDMI displays at the same time, without distorting or degrading your video signal. For dependable performance, the splitter features a durable metal housing that provides passive cooling.
With transmission bandwidth up to 18Gbps, this HDMI splitter is fully compatible with your HDMI 2.0 equipment, supporting UHD resolutions up to 4096x2160 (4K) at 60Hz. For smooth video and color transitions, the splitter offers 4:4:4 chroma subsampling, so every pixel gets its own unique color.
The splitter also supports High Dynamic Range (HDR) imaging, offering a greater luminosity than standard digital imaging.
The 2-way HDMI splitter supports HDCP 2.2 and is backward compatible with 4K 30Hz and 1080p displays. This ensures that it will work with almost any HDMI source, or destination device such as computers, Blu-ray players, monitors, TVs and projectors. Perfect for digital signage applications, where equipment may vary throughout your site.
For hassle-free setup, the 1x2 HDMI splitter offers easy plug-and-play installation. The splitter also saves you setup time by automatically passing EDID between your video source and the display attached to port 1, ensuring settings like native resolution and refresh rate are configured properly.
  • True 4K at 60Hz and HDR
    With transmission bandwidth up to 18Gbps, this HDMI splitter is fully compatible with your HDMI 2.0 equipment, supporting UHD resolutions up to 4096x2160 (4K) at 60Hz. For smooth video and color transitions, the splitter offers 4:4:4 chroma subsampling, so every pixel gets its own unique color. The splitter also supports High Dynamic Range (HDR) imaging, offering a greater luminosity than standard digital imaging.
  • Widely Compatible
  • Easy Installation
    For hassle-free setup, the 1x2 HDMI splitter offers easy plug-and-play installation. The splitter also saves you setup time by automatically passing EDID between your video source and the display attached to port 1, ensuring settings like native resolution and refresh rate are configured properly. ST122HD202 is backed by a 2-year StarTech.com warranty and free lifetime technical support.
StarTech.com HDMI Splitter - 2-Port - 4K 60Hz - HDMI Splitter 1 In 2 Out - 2 Way HDMI Splitter - HDMI Port Splitter (ST122HD202) - video/audio splitter - 2 ports
Video/audio splitter - 2 ports
Subtype
HDMI
Ports
2 x HDMI
7.1 channel audio support, Dolby TrueHD support, DTS-HD Master Audio support, HDR support
HDCP 2.2
AC 120/230 V
10 cm x 5.6 cm x 1.7 cm
159 g
Australia, New Zealand, North America, United Kingdom, Europe
P/N: ST121HD20FXA
Enclosure Type
Desktop
Subtype
HDMI
Ports
2 x HDMI
Max Resolution
3840 x 2160 @ 60 Hz
HDCP 2.2
Status Indicators
1 x HDMI input , 2 x HDMI output
External power adapter
AC 120/230 V
5 Watt
FCC, RoHS, WEEE
10 cm
5.6 cm
1.7 cm
159 g
20 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
P/N: ST121HD20FXA
DXFV StarTech.com 4 Port High Speed HDMI Video Splitter w/ Audio In Stock £91.53
DXFV StarTech.com 4K HDMI 2-Port Video Splitter – 1x2 HDMI Splitter – Powered by USB or Power Adapter In Stock £50.75
DXFV StarTech.com 5m DisplayPort to HDMI Cable - 4K In Stock £20.76
DXFV StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £16.00
DXFV StarTech.com 3m 10ft Premium HDMI 2.0 Cable In Stock £20.46
DXFV StarTech.com 5m 15ft Premium 4K HDMI Cable In Stock £24.69
DXFV StarTech.com 7m 23ft Premium 4K HDMI Cable In Stock £36.43
DXFV StarTech.com 0.5m Premium 4K HDMI Cable In Stock £9.95
DXFV StarTech.com 10m CL2 Active HDMI Cable - 4K In Stock £81.45
DXFV StarTech.com 15m CL2 Active HDMI Cable - 4K In Stock £97.80
DXFV StarTech.com 8-Port 4K 60Hz HDMI Splitter In Stock £133.22
DXFV StarTech.com HDMI Splitter - 2 Port - 4K 60Hz In Stock £39.58
DXFV StarTech.com HDMI Splitter - 4 Port - 4K 60Hz In Stock £55.73
DXFV StarTech.com 2-Port HDMI Splitter, 4K 60Hz In Stock £52.11
