Maximize cost-savings and performance with this bulk pack of single-mode/ multi-mode Mini-GBIC modules. Perfect for large-scale deployments or installations on multiple devices, this bulk pack of Gigabit fiber SFPs provides maximum cost savings. Built to exacting specifications and fully tested to ensure optimum performance, these high-quality transceiver modules can be installed into Cisco switches and routers that support the GLC-LH-SM transceiver module, as well as other major brands of networking equipment.
The SFP transceivers provide a dependable and cost-effective way to add, replace or upgrade the Gigabit fiber ports on your 1000Base-LX/LH networking equipment, and they're backed by a lifetime warranty.
The single-mode/multimode SFP transceivers included in this 10-pack are manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. Committed to the highest standards of quality, StarTech.com produces an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
These Gigabit single-mode/multimode SFPs are engineered to the highest quality standards and are 100% Cisco compatible, equivalent to the Cisco GLC-LH-SM SFP transceiver. StarTech.com SFP transceivers are configured and fully tested to ensure they work seamlessly with Cisco or other major brands of networking equipment.
You can be assured that the use of StarTech.com SFP products should not affect the warranty protection of your networking equipment.
Delivering both convenience and scalability, these fiber transceivers are fully hot-pluggable which enables you to install them without interrupting network traffic or having to reboot your equipment. They provide a versatile and cost-effective solution that's compatible with a multitude of Gigabit networking devices.
Ideal for use in switches, routers and other networking equipment, the SFPs provide reliable performance, enabling you to expand your network to remote segments cost-effectively. The SFPs support both single-mode (with a maximum distance of 10 km or 6.2 mi.) and multimode (with a maximum distance of 550 m or 1804 ft.) and maximum data rates up to 1.25Gbps.
You can count on GLCLHSM10PST for reliable performance,.
- StarTech.com Cisco GLC-LH-SM Compatible SFP Module, 1000BASE-LX/LH, 1GbE SMF Optic Transceiver, LC Connector, 10km, 1310nm Cisco Firepower, ASR920, IE2000 Mini GBIC Transceiver 1GE SFP - Lifetime Warranty (GLCLHSM10PST) - SFP (mini-GBIC) transceiver module - 1GbE
- SFP (mini-GBIC) transceiver module - LC
- Packaged Quantity
- 10 (specifications are for single item)
- Form Factor
- Plug-in module
- Cabling Type
- 1000Base-LX, 1000Base-LH
- Data Transfer Rate
- 1.25 Gbps
- Optical Wave Length
- 1310 nm
- Data Link Protocol
- 1GbE
- Max Transfer Distance
- 10 km
- OEM Manufacturer Equivalent Part Number
- Cisco GLC-LH-SM
- 1.37 cm x 5.66 cm x 1.25 cm
- 25 g
- Limited lifetime warranty
- Packaged Quantity
- Form Factor
- Plug-in module
- Silver
- Connectivity Technology
- Wired
- Cabling Type
- 1GbE
- 1.25 Gbps
- 1310 nm
- 10 km
- Full duplex mode
- IEEE 802.3z
- 1 x Ethernet 1000Base-LX/1000Base-LH - LC female x 2
- FCC, RoHS, MSA
- Cisco GLC-LH-SM
- 1.37 cm
- 5.66 cm
- 1.25 cm
- 25 g
- Limited warranty - lifetime
- 0 °C
- 70 °C
- 5 - 95%
|  | StarTech.com 1m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £13.98 |
|  | StarTech.com 10m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £23.49 |
|  | StarTech.com 2m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £15.11 |
|  | StarTech.com 5m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £19.13 |
|  | StarTech.com 3m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £16.60 |
|  | StarTech.com 7m Single Mode Duplex Fiber Patch Cable LC-LC | In Stock | £20.78 |
|  | StarTech.com 10m Single Mode Duplex Fiber Patch Cable LC-LC | In Stock | £23.55 |
|  | StarTech.com 1m Single Mode Duplex Fiber Patch Cable LC-LC | In Stock | £17.09 |
|  | StarTech.com 4m Single Mode Duplex Fiber Patch Cable LC-LC | In Stock | £18.98 |
|  | StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC | In Stock | £139.16 |
|  | StarTech.com Fiber Media Converter - Open | In Stock | £42.26 |
|  | StarTech.com Gigabit Fiber SFP - 10 Pack | In Stock | £223.31 |
|  | StarTech.com Gigabit Fiber SFP - 10 Pack | In Stock | £218.03 |
|  | StarTech.com Gb Fiber SFP - Cisco Compatible | In Stock | £37.25 |
|  | StarTech.com Gigabit Fiber SFP - 10 Pack | In Stock | £223.87 |
|  | StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports | In Stock | £320.87 |
