StarTech.com Dual-Port QSFP+ NIC Card
Quicklinx: DBXYWS00 Mfr#: PEX40GQSFDPI
Get fast, high-bandwidth connectivity with the Dual-Port QSFP+ Network Interface Card. It adds two open QSFP+ slots to your server or workstation. It's ideal for high-demand database servers, virtualized servers and agile data centers that require infrastructure updates with no downtime.
  • Increase your network speed
    The Dual-Port QSFP+ Server NIC card lets you take advantage of the speed and stability of a 40 Gigabit network, with incredible data transfers.
  • Add redundant connections in zero-downtime environments
    With two QSFP+ ports, the PCIe NIC helps to prevent network downtime by adding fault-tolerant connections using two modules, to provide high-bandwidth network links to your mission-critical servers or workstations.
  • Add scalable network connections
    With its open QSFP+ slots, the network interface card supports QSFP+ transceiver modules and is compatible with multimode and single-mode fiber, providing a scalable networking solution.
StarTech.com Dual Port 40G QSFP+ Network Card, Intel XL710 Open QSFP+ Converged Adapter, PCIe 40 Gigabit Ethernet Server NIC, 40GbE Fiber Optic LAN Card, Dell PowerEdge HPE ProLiant, 40Gb - Network Interface Card - network adapter - PCIe - 40 Gigabit QSFP+ x 2
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express
Ports
40GbE
Data Transfer Rate
40 Gbps
Intel XL710
Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows Server 2012 x64 Edition, Microsoft Windows Server 2012 R2 x64 Edition, Microsoft Windows 7 / 8 / 8.1 / 10 (64 bits), Microsoft Windows Server 2016 (64-bit), Linux 2.6.24 - 4.11.x (64-bit) LTS versions, Microsoft Windows Server 2019 (64-bit)
Network adapter
Plug-in card
PCI Express
Ports
Wired
40 Gigabit Ethernet
Data Transfer Rate
40 Gbps
Processor / Memory
Intel XL710
2 x 40Gb Ethernet - QSFP+
DBXY StarTech.com QSFP+ Network Card - PCIe In Stock £300.75
