StarTech.com Dual M.2 PCIe SSD Adapter Card
Quicklinx: H5LJWS00 Mfr#: DUAL-M2-PCIE-CARD-B
20 In Stock
£61.33 ex VAT
£73.59 inc VAT
This Dual M.2 PCIe SSD Adapter adds two high performance PCIe M.2 SSDs (NVMe and AHCI) into the PCIe x8 or x16 slot of a desktop, workstation, or server.
  • Boost System Performance
    Take full advantage of the fast performance and compact size of PCIe M.2 internal solid-state drives, with read and write speeds up to 7.8GBps per drive.
  • Access two M.2 PCIe SSDs simultaneously
    No on-board chip leads to wide system compatibility. This card requires PCIe bifurcation, meaning it easily integrates into any system with an available x8 or x16 PCIe slot that supports PCIe bifurcation. Utilize software RAID, such as Storage Spaces (Microsoft) or mdraid/mdadm (Linux), to build a RAID array, adding redundancy or enhancing system performance.
  • Wide Compatibility
    The PCIe M.2 NGFF (M Key or B+M Key) adapter supports PCIe NVMe and PCIe AHCI M.2 SSDs including 2242, 2260, 2280 and 22110mm drives. The PCIe M.2 Adapter Card does not require any software or drivers, meaning it works with most operating systems, if the computer/motherboard supports bifurcation.
  • Vented Brackets
    The included full and low-profile vented brackets increase air flow to improve heat dissipation, which aids in maintaining optimal and reliable operating temperatures. The DUAL-M2-PCIE-CARD-B is backed for 2-years by StarTech.com, including free 24/5 multi-lingual technical assistance
StarTech.com Dual M.2 PCIe SSD Adapter Card, x8 / x16 Dual NVMe or AHCI M.2 SSD to PCI Express 4.0, Up to 7.8GBps/Drive, For 2242/2260/2280/22110mm PCIe M-Key M2 SSDs, Bifurcation Required - PC/Linux Compatible (DUAL-M2-PCIE-CARD-B) - interface adapter - M.2 Card - PCIe 4.0 x16/x8
Interface adapter - plug-in card - low profile
Bus Type
PCIe 4.0 x16/x8
Red
Supported Form Factor
Expansion Slot to 2 x M.2
Expansion Bays
2 x internal - M.2 2242/2260/2280/22110
Hard Drive Form Factor Compatibility
M.2
M.2 Card
Data Transfer Rate
7.8 GBps
Supported Devices
Solid state drive
Max Storage Devices Qty
2
RAID Level
RAID 0, RAID 1, JBOD
2.2 cm x 22.8 cm x 10.2 cm
74 g
M.2
Host Bus
PCIe 4.0 x16/x8
Red
Storage Controller
M.2 Card
Data Transfer Rate
7.8 GBps
Supported Devices
Solid state drive
2
RAID Level
Bays
Low-profile bracket
Supports AHCI mode, PCIe bifurcation, LED indicator
2.2 cm
22.8 cm
10.2 cm
74 g
Shipping Width
17 cm
Shipping Depth
29 cm
Shipping Height
3 cm
Shipping Weight
192 g
-40 °C
80 °C
15 - 90%
H5LJ StarTech.com M.2 NVMe SSD to PCIe x4 Slot In Stock £77.11
H5LJ StarTech.com Dual M.2 NVMe SSD to PCIe x8 In Stock £135.29
