StarTech.com M.2 NVMe SSD to PCIe x4 Slot
Quicklinx: HHXCWS00 Mfr#: M2-REMOVABLE-PCIE-N1
Type: Interface adapter
HD Size: M.2
£79.04 ex VAT
£94.84 inc VAT
  • Effortless installation
    Experience the convenience of toolless installation, making it easier than ever to upgrade your system with NVMe SSDs. This feature ensures a hassle-free setup, allowing you to enjoy enhanced storage capabilities without the need for additional tools.
  • Enhanced security
    With the inclusion of a key lock and 2 keys, this mobile rack/backplane offers an added layer of security for your valuable data. Protect your SSD from unauthorized access, ensuring that your information remains safe and secure.
  • High-speed performance
    Leveraging PCIe 4.0 technology, this adapter supports data transfer rates up to 64 Gbit/s, providing a significant boost in performance for high-speed data access and storage. Ideal for professionals and enthusiasts seeking improved storage solutions.
  • Durable design
    Constructed from stainless steel, this mobile rack/backplane is designed to withstand the rigors of daily use. Its anti-vibration springs further protect your SSD, ensuring stable performance and a longer lifespan for your device.
  • Smart compatibility
    Supports a wide range of M.2 form factors and is compatible with 4Kn drives, S.M.A.R.T., and TRIM. This versatility ensures that you can use SSDs on the market, making it a smart investment for your storage needs.
StarTech.com M.2 NVMe SSD to PCIe x4 Mobile Rack/Backplane with Removable Tray for PCI Express Expansion Slot, Tool-less Installation, PCIe 4.0/3.0 Hot-Swap Drive Bay, Key Lock - 2 Keys Included - interface adapter - M.2 NVMe Card / PCIe 4.0 (NVMe) - PCIe 4.0 x4
Interface adapter - plug-in card
Bus Type
PCIe 4.0 x4
Black, silver
Expansion Bays
1 x internal - M.2 2230/2242/2260/2280
Hard Drive Form Factor Compatibility
M.2
Data Transfer Rate
64 Gbit/s
Supported Devices
Solid state drive
Max Storage Devices Qty
1
Product Material
Stainless steel
1.9 cm x 16.7 cm x 12 cm
65 g
StarTech.com Expansion Slot Rear Exhaust Cooling Fan with LP4 Connector (FANCASE)
M.2
Host Bus
PCIe 4.0 x4
Product Material
Stainless steel
Black, silver
Storage Controller
Data Transfer Rate
64 Gbit/s
Supported Devices
Solid state drive
1
Bays
1 x M.2 Card - M.2 M key (internal)
1 x PCIe 4.0 x4
2 security keys, low-profile bracket
Hot-swappable strorage bay, key lock, tool-less installation, LED indicator, anti-vibration springs, TRIM support, 4Kn drive compatible, S.M.A.R.T. support, bus powered, supports NVM Express
MTBF
10,000 hours
RoHS, WEEE
1.9 cm
16.7 cm
12 cm
65 g
Shipping Width
4.6 cm
Shipping Depth
23 cm
Shipping Height
15.1 cm
Shipping Weight
215 g
65 °C
0 - 90% RH
HHXC StarTech.com M.2 NVMe Drive Tray In Stock £27.38
HHXC StarTech.com Dual M.2 NVMe SSD to PCIe x8 In Stock £121.76
HD Size: M.2
