StarTech.com Dual M.2 NVMe SSD to PCIe x8
Quicklinx: J1JSWS00 Mfr#: 2M2-REMOVABLE-PCIE
Hurry, only 1 left in stock!
£121.76 ex VAT
£146.11 inc VAT
The Dual-Bay M.2 NVMe SSD Removable Mobile Rack provides an efficient solution for expanding storage capabilities via PCIe x8 slots. With a capacity to accommodate up to two M.2 drives, this interface adapter supports various lengths from 2230 to 2280, ensuring compatibility with a wide range of SSDs. Equipped with a hot-swap feature, the mobile rack allows seamless drive replacements without powering down the system, contributing to improved productivity and convenience. This mobile rack also integrates essential features such as S.M.A.R.T. support, TRIM support, and a key lock for added security. Built from stainless steel, it ensures durability while the LED indicator provides operational status for drives. Additionally, the tool-less installation process simplifies setup, making it an ideal choice for enhancing storage solutions efficiently.
  • Convenient hot-swap capability
    This mobile rack allows users to replace M.2 drives without powering down the system, enhancing operational efficiency.
  • Robust build quality
    Constructed from stainless steel, this device ensures longevity and protection for internal components against various environmental factors.
  • Efficient data transfer rates
    With a data transfer rate of 128 Gbit/s, this mobile rack supports high-speed connections and optimal performance for solid-state drives.
  • Support for multiple M.2 sizes
    Designed to accommodate M.2 drives of sizes 2230, 2242, 2260, and 2280, providing flexibility and compatibility for diverse storage needs.
  • User-friendly installation
    Features a tool-less installation process, simplifying setup and making it accessible for users of all technical levels.
StarTech.com Dual-Bay M.2 NVMe SSD Removable Mobile Rack for PCIe x8 Slot - interface adapter - M.2 NVMe Card / PCIe (NVMe) - PCIe 4.0 x8
Interface adapter - plug-in card
Bus Type
PCIe 4.0 x8
Expansion Bays
2 x hot-swap - M.2 2230/2242/2260/2280
Hard Drive Form Factor Compatibility
M.2
Data Transfer Rate
128 Gbit/s
Supported Devices
Solid state drive
Max Storage Devices Qty
2
Product Material
Stainless steel
18.6 cm x 12.1 cm x 1.9 cm
500 g
M.2
Host Bus
PCIe 4.0 x8
Product Material
Stainless steel
Storage Controller
Data Transfer Rate
128 Gbit/s
Supported Devices
Solid state drive
2
Bays
2 x M.2 Card - M.2 M key (internal)
X PCIe 4.0 x8
2 x M.2 mounting screws, keys
Hot-swappable strorage bay, key lock, tool-less installation, LED indicator, vented, anti-vibration springs, TRIM support, S.M.A.R.T. support, 4Kn drive compatible, bus powered, supports NVM Express
MTBF
40,000 hours
RoHS
18.6 cm
12.1 cm
1.9 cm
500 g
Shipping Width
23 cm
Shipping Depth
15.1 cm
Shipping Height
4.6 cm
Shipping Weight
500 g
50 °C
10 - 60% RH
J1JS StarTech.com M.2 NVMe SSD to PCIe x4 Slot In Stock £79.04
J1JS StarTech.com M.2 NVMe Drive Tray In Stock £27.38
