Effortless installation
Experience the convenience of toolless installation, making it easier than ever to upgrade your system with NVMe SSDs. This feature ensures a hassle-free setup, allowing you to enjoy enhanced storage capabilities without the need for additional tools. -
Enhanced security
With the inclusion of a key lock and 2 keys, this mobile rack/backplane offers an added layer of security for your valuable data. Protect your SSD from unauthorized access, ensuring that your information remains safe and secure. -
High-speed performance
Leveraging PCIe 4.0 technology, this adapter supports data transfer rates up to 64 Gbit/s, providing a significant boost in performance for high-speed data access and storage. Ideal for professionals and enthusiasts seeking improved storage solutions. -
Durable design
Constructed from stainless steel, this mobile rack/backplane is designed to withstand the rigors of daily use. Its anti-vibration springs further protect your SSD, ensuring stable performance and a longer lifespan for your device. -
Smart compatibility
Supports a wide range of M.2 form factors and is compatible with 4Kn drives, S.M.A.R.T., and TRIM. This versatility ensures that you can use SSDs on the market, making it a smart investment for your storage needs.
- StarTech.com M.2 NVMe SSD to PCIe x4 Mobile Rack/Backplane with Removable Tray for PCI Express Expansion Slot, Tool-less Installation, PCIe 4.0/3.0 Hot-Swap Drive Bay, Key Lock - 2 Keys Included - interface adapter - M.2 NVMe Card / PCIe 4.0 (NVMe) - PCIe 4.0 x4
- Interface adapter - plug-in card
- Bus Type
- PCIe 4.0 x4
- Black, silver
- Expansion Bays
- 1 x internal - M.2 2230/2242/2260/2280
- Hard Drive Form Factor Compatibility
- M.2
- Interface
- Data Transfer Rate
- 64 Gbit/s
- Supported Devices
- Solid state drive
- Max Storage Devices Qty
- 1
- Product Material
- Stainless steel
- 1.9 cm x 16.7 cm x 12 cm
- 65 g
- 2-year warranty
- Designed For
- StarTech.com Expansion Slot Rear Exhaust Cooling Fan with LP4 Connector (FANCASE)
- M.2
- Host Bus
- PCIe 4.0 x4
- Product Material
- Stainless steel
- Black, silver
Storage Controller
- Interface
- 64 Gbit/s
- Supported Devices
- Solid state drive
- 1
- Bays
- 1 x M.2 Card - M.2 M key (internal)
- Connections
- 1 x PCIe 4.0 x4
- Included Accessories
- 2 security keys, low-profile bracket
- Hot-swappable strorage bay, key lock, tool-less installation, LED indicator, anti-vibration springs, TRIM support, 4Kn drive compatible, S.M.A.R.T. support, bus powered, supports NVM Express
- MTBF
- 10,000 hours
- RoHS, WEEE
- Limited warranty - 2 years
- 1.9 cm
- 16.7 cm
- 12 cm
- 65 g
- Shipping Width
- 4.6 cm
- Shipping Depth
- 23 cm
- Shipping Height
- 15.1 cm
- Shipping Weight
- 215 g
- 0 °C
- 65 °C
- 0 - 90% RH
- Designed For
StarTech.com M.2 NVMe Drive Tray | In Stock | £28.64 |
StarTech.com Dual M.2 NVMe SSD to PCIe x8 | In Stock | £121.76 |
